Re: Oil in Radiator Resourvour and oozing out.
Is there actually oil in the de-gas bottle or in the radiator itself?
If there is just oil on the outside of the radiator he may just need a new oil cooler or need to tighten the lines on the oil cooler. I have seen lines get loose on an oil cooler and then when you drive around the leaking oil gets blown back all over everything behind it and makes things look alot worse than they are.
06 F350XL rc,lb,manual 4x4, 6.0 PSD, 6 speed
Upfitter Switches
BCP Idle Control
55 watt halogen back up lights (4)
200 psi 5 gallon air system
Diesel Site Coolant Filter
HELLA FF50 Fog Lights
Custom Headache Rack
Custom Shovel Rack
Weatherguard Saddle Box
Weathergaurd Wheel Well Box
Herculiner wheel wells and rocker panels
Edge Insight with EGT and Fuel Pressure
