Oil Rail Bolt Removal - Diesel Forum - TheDieselStop.com
Old 11-13-2009, 08:29 PM   #1 (permalink)
In the middle of replacing passenger side fuel injectors on 2004 6.0 Excursion.
Finale got valve cover bolts out and all but two lower back oil rail bolts out. Any trick to get the last two out and then back in and torquing them down. Evap case is in the way.
Swan59 is offline
Old 11-14-2009, 11:14 AM   #2 (permalink)
speedrcr78's Avatar
Take a ratcheting 1/4 wrench and use just a t-30 bit. Be careful not to drop the bit into the head. Otherwise you are going to have to remove the a/c stuff
speedrcr78 is offline
