Oil and romp - Diesel Forum - TheDieselStop.com
Old 12-28-2012, 08:03 AM   #1 (permalink)
Oil and romp
Trying to figure out the romp on my Excursion. Just changed the oil with Motorcraft 15/40. Romps pretty good in morning in 30 to 40 temp. Since the oil was just changed with new filter, I was thinking of draining oil and replacing with T6 and leave the newly changed filter in place. ..... No filter change.
Any harm with this?
Thanks. Jed
2005 F350 6.0 Super Crew
2005 Excursion 6.0
jed1894 is offline   Reply With Quote
Old 12-28-2012, 08:40 AM   #2 (permalink)
Derkperk's Avatar
Nope. The lighter weight will help. You could always set up a timer to energize your block heater a couple hours before you start the ex so the oil is warm and ready to go.
Derkperk is offline   Reply With Quote
Old 12-28-2012, 10:34 AM   #3 (permalink)
Yep, thought about that too. Was thinking more about when away from home, which is all I use it for. Not sure if the oil is my problem.......... It took 5 times to get it going this morning at 32 degrees. It just kicked over and stopped. Finally got it going. It was just 32 so anything lower will be more problems I'm sure. I will put the T6 in over the weekend and see if that helps. This will be a very good experiment on syn oil vs Dino oil and cold starts. I will know for sure (at least in my case) if syn oil helps with my particular romp.
Thanks for post, jed
2005 Excursion 6.0
Old 12-28-2012, 12:01 PM   #4 (permalink)
No check engine light? You might have lost some glowplugs. Also what is your battery voltage.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator replacement, 2 batteries; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors and replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty.
Ford06 is offline   Reply With Quote
Old 12-28-2012, 04:17 PM   #5 (permalink)
I did get and engine light the other day, but the scanner said it was EGR valve. I cleared the code and it has not returned. Battery voltage is good question. Don't know that one. I will check this weekend. One other thing I did not think of......I have not cranked it about a week and it was 32 this morning. The batteries did turn over slower than the last time. Might just have weak battery issue.....
Thanks, jed
2005 Excursion 6.0
Old 12-30-2012, 09:31 AM   #6 (permalink)
Update: The syn oil (T6) did not stop the romp. Changed it out yesterday and just started up in 35 degree. Still had romp, but did not seem as bad.....maybe because I run it yesterday to get the oil moving around. HOWEVER....
I got my ScangaugeII hooked up and the FMP (FICM) reading was 35 to 36. Battery voltage was 13.8. So, unless the reading was thrown off because I programmed it in another vehicle (F350), I guess I have a FICM going bad.
Any suggestions? Thanks, jed
2005 Excursion 6.0
Old 12-30-2012, 10:10 AM   #7 (permalink)
I went over all the codes in the SC.....here are the final numbers:
With key on (no crank)
FMP: 48
FLP: 11
FVP: 11
VLT: 11.3
Cranked up (running):
FMP: 35 to 39.5
FLP: 13 to 13.5
FVP: 13.5
VLT: 13.5
This all done while idling in drive way.
Note: I posted this over in ***************** as well for those of you that are members there too.
jed
2005 Excursion 6.0
Old 12-30-2012, 11:37 AM   #8 (permalink)
jed
If you have injector stiction, changing to 5W-40 Syn will not IMMEDIATELY cure romp.
It needs to be used for a couple weeks and possibly run some RevX or Hot Shots Secret to clean the built up varnish out of the injector spools.
2003 F250 XLT Sport Ext Cab ESOF FX4 6.0L TorqShift, Sonic Blue/Black Leather.
BrakeSmart Trailer Brake controller.
Leer Cab high Browning Edition Cap.
2004 SunnyBrook Solanta 28' TT small slide 7800#
35 Years in the trenches!
Retired Machinist & Manufacturing Engineer for fuel control systems for very large Diesel Engines. Locomotives to Super Tankers.
Designed and trouble shot manufacturing processes for stuff from Design Engineers. Sometimes had to wrestle for design changes.
Designed and built tools and equipment to machine, assemble, disassemble, repair and test.
Wisdom comes with age, but sometimes age comes alone.
"Nothing is FOOLPROOF because fools are too ingenious"-Mark Twain
johnmart is offline   Reply With Quote
Old 12-30-2012, 12:41 PM   #9 (permalink)
Well, your FICM is bad. You might or might not have other issues. The latest ECU flash from Ford will make it start quite well if nothing else is broken. Since the FICM is bad and you are still driving it, you may get to change out the injectors as well. Glow plugs will throw a code and light the CEL.
Brian
MC5C is offline   Reply With Quote
Old 12-30-2012, 03:19 PM   #10 (permalink)
Originally Posted by johnmart View Post
jed
Got it. Thanks. I plan to keep it in there.....
2005 Excursion 6.0
Old 12-30-2012, 03:21 PM   #11 (permalink)
Brian
Thanks for information. Got it parked now. Plan on taking to Ford this week.
jed
2005 Excursion 6.0
Old 01-02-2013, 11:56 AM   #12 (permalink)
Sending the FICM to Ed at FICMrepair would be a better option than Ford.
Old 01-02-2013, 06:12 PM   #13 (permalink)
HeavyAssault's Avatar
My Photos: (6)
How many quarts did you pour into the motor??
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline   Reply With Quote
Old 01-03-2013, 03:18 PM   #14 (permalink)
Is this a trick question? ... got between 14 and 15 quarts in it (I think 14.7 to be exact).
jed
2005 Excursion 6.0
Old 01-03-2013, 06:25 PM   #15 (permalink)
My Photos: (6)
In the past people were overfilling the truck by using 15-16 quarts. This alone caused "romps" due to the lower crank slopping the oil as I recall.
