Okay Boys This Girl Needs Help! - Page 3 - Diesel Forum - TheDieselStop.com
Old 11-01-2009, 10:35 AM   #31 (permalink)
Diesel Girl's Avatar
Originally Posted by Strokin' 6.0 View Post
I won't go there....
I don't blame you.......oh well it was fun!
2006 Ford F250 Powerstroke crewcab with 30,000 miles. 6" rough country lift with 4 link suspension, 20" Mickey Thompson wheel with simulated bead lock, 35" Mickey Thompson Tires with sidebitter. ARP Head Studs.
Diesel Girl is offline
Old 11-06-2009, 10:25 AM   #32 (permalink)
mms://multimedia.ford.com/seopts/Tech4_250k.wmv
FEBRUARY 2004 F350 CREW DUALLY,60K, 6.0L/6 SPEED/3.73/2WD,
EGR SPOOL, INSULATED WRAP CAC,BUTTERFLY DELETE,ACCUFAB INLET ELBOW,MUFF TUBE,BED COVER,BREATHER VENT MOD,OB1308 BY-PASS FILTER BASE,upgrade fuel return pressure spring 30# increase, velvet ride shackles, tranny cooler/filter,COOLANT FILTER,redline wetterbetter,1704A SUPERCHIP, SCHAFFERS 9000, 22MPG EMPTY @ 55MPH in cruise. Last fill up calculated @ 18mpg Hobbies- sticking my head out the window like a dog and hauling ass on the scooter rain or shine
pigsbreath is offline
Old 12-09-2009, 04:32 PM   #33 (permalink)
Okay.....here is an update on my leaking situation. Two weeks before turkey day the dealer put 2 bottles of dye in it and then I took it home and drove the crap out it, took it back in on the 30th and it has been there ever since. Apparently it was leaking so bad that it looked like a crime scene with the blacklight, so the mechanic still had no idea where it was coming from. Now get this Ford would not let him take the engine apart to see where it was coming from, they only allowed him to remove the turbo. That didn't help and he suspected it was the heads (yea), so I found out yesterday that yes it is the head gaskets and of course the culprit is the head bolts. So I get a call this morning and the service advisor told me that Ford denied the claim to fix the head gaskets, they want him to replace the glow plug harness and then put different color dye in it and run a smoke machine to see if it is still leaking. Even thou the diesel mechanic knows it is the heads, Ford doesn't trust his judgement, so now there is a Ford engineer coming out to tell the mechanic how to fix it. I am soooooo freakin mad, I am about to blow a gasket myself. So now I wait like I have for the past week and a half, but I have a feeling if the head gaskets get fixed that they won't replace the stretched head bolts, so I am going to purchase some ARPhead bolts if they don't replace them.
Anyone have a similar experience or can anyone vouch forthe ARP head bolts?
Old 12-09-2009, 04:55 PM   #34 (permalink)
OT
OT's Avatar
DG..its a bummer I agree, but u gotta grin & bare it best you can. Cant sidestep what FMC is dictating, but hopefully your tec. & fmc rep. put their heads together & fix it. Mean time...
Head bolts arent reusable. Studs are, but my dealer/shop wouldnt install due to warr. still in effect at time my repairs done. Didnt drip oil, just water. Good luck!
btw...my turbo, headbolts/h.g. repair still ok today. Still one o. leak never got fixed, but its not a bad dripper (so far) I suspect its bedplate?
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 12-09-2009, 04:56 PM   #35 (permalink)
1954oldred's Avatar
Are You sure You didn't take your truck to Washington D.C. where Harry Reid and Nancy Pelosi , the Experts at what We all need and want, run things? Sorry, couldn't resist !
In the end we will remember not the words of our enemies but only the silence of our friends
2006 F350 C/C SRW S/B Lariat FX4, SCT X3 W/ID Custom tunes, Coolant Filter, CCV Mod, High Idle Mod, fog light mod, EGR Delete, 3.5" MBRP stainless Downpipe, 4" MBRP Stainless the rest of the way, Swamps FICM,Edge Insight Gauges,18" BFG'S, 120k
God, Country, The Citadel
1954oldred is offline
Old 12-09-2009, 06:53 PM   #36 (permalink)
0660harley's Avatar
DG - Just chiming in to wish you a speedy recovery. I had a oil leak diagnosed to one of the HPOP fittings on the topside of the engine. It was a slow leak which was pooling in the engine valley and running down the backside of the engine. Thankfully they correctly diagnosed my leak and fixed it right the first time. I've had no leaking since. I'm certianly no expert at all on these engines, but wouldn't faulty head gaskets also result in leaking coolant or a cross contamination situation (mixing of oil/coolant)?
06 F-250 6.0 PSD Harley Davidson Edition
0660harley is offline
Old 12-09-2009, 09:59 PM   #37 (permalink)
dikkstarr's Avatar
Yeah, get the studs, after theyr in you will never have to worry about blown HG again. Thats a wierd deal with the Ford guys, but if you still have warranty left they should fix it and put the studs in while their at it. They did for me.
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
Old 12-09-2009, 10:53 PM   #38 (permalink)
ace-tron's Avatar
I would find another dealership!
ace-tron is offline
Old 12-10-2009, 07:30 AM   #39 (permalink)
That is the thing, it is not the dealership......it is the higher ups at Ford. Apparently the mechanics have to get approval to do the work, I guess it is kindof like having to get a PO# before you can purchase anything.
The guys at the dealership have been great, I even have the one guys cell number, so it is not them at all.
Old 12-10-2009, 07:32 AM   #40 (permalink)
I was thinking the same thing, I read an article in Diesel World about the whole 6.0 things that was written by Banks. I remember them saying that coolant would be mixed with the oil if it was a head gasket problem, I am going to ask them about that today, since that was never mentioned.
Old 12-10-2009, 07:38 AM   #41 (permalink)
Originally Posted by dikkstarr View Post
[/color][/b]
I told the service advisor at Ford that I was going to buy those studs and have them replace them when they put the engine back together. I guess I would rather pay $500 now then thousands later. Yeah, the whole service shop is completely in ahhh about the whole thing, the person I feel bad for is the mechanic, if I was him I would felt like Ford just kicked me in the balls for not trusting my judgement.
Old 12-10-2009, 10:47 AM   #42 (permalink)
OT
OT's Avatar
DG..if h.g. do get replaced & studs installed be sure you have clear understanding with tec. (for argument sake) if anything should go wrong with this type repair while still under warr. will it still be covered.? I doubt tec. will list on warr. r/o..studs installed because not approved by fmc. Anyhow, good luck & hopefully fixed soon.
OT is offline
Old 12-10-2009, 10:56 AM   #43 (permalink)
Dustin58's Avatar
Save your self some money on the oil filter. Ford use's Fram for there Motorcraft filter. So when at the store looking for an oil filter the Motorcraft and Fram filter are the same.
2005 F-250 4x4 CREW CAB
BANKS SIX GUN.
ARAID INTAKE
BOOST RELIEF VALVE
BANKS INTERCOOLER
4.5 INCH DONAHOE LIFT
MAG HYTEC REAR COVER
37 TOYO MUDS
4 INCH TURBO BACK RBP EXHAUST
4 TURBOS
3 SETS OF HEAD GASKETS
2 EGRS AND COOLERS
1 SET OF HEADS
1 TRANNY AT 47K
4 BATTERIES
Dustin58 is offline
Old 12-10-2009, 11:53 AM   #44 (permalink)
prohydroracer's Avatar
Are you sure about that? I was under the Impression that Racor built the filters for Motorcraft and International
2004 F-250 Lariat Ex-Cab Long Box
  • ARP Stud's
  • MBRP 4" Turbo Back
  • Oil and Coolant Bypass Filters
  • SCT w/Custom Tunes
  • Fuel Pressure, HPOP Pressure, Boost and EGT on the A-Pillar
  • Edge Insight monitors EOT, ECT, Tranny Temp
  • Full Security with Remote Start
  • Anti Hi-Jack Device by GLOCK!
prohydroracer is offline
Old 12-10-2009, 04:51 PM   #45 (permalink)
The Fram and Motorcraft are the same.... Just repackaged. I compared the patent #'s on them and all....
RC
2007 F250 6.0L Lariat
122,000 Miles
90% Highway Driving
Dieselsite Coolant Filter
PIAA Driving lights installed in Stock foglight spot
Edge Insight Monitor with Dash Pod
Pioneer Avic Z2 Nav w/ Sirius Satellite Radio
CB Radio w/ Firestik Antenna w/ Hood Mount
06 Harley V-Rod Street Rod Yellow
Rccarps2 is offline
