Opti-Lube XPD fuel additive observations - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 01-06-2012, 05:52 PM Thread Starter
So I have started to use Opti-Lubes XPD in my 2004 6.0 F250.
I have used it in the last 3 fill ups and here are my observations;
I ordered it from Opti-Lube and they ship FAST! I started with an initial shipment of 2 qts and then got the 1 gallon kit which comes with an 8 oz bottle and a hand pump for the gallon contanier. Both shipments survived my UPS drivers quaterback toss over my front gate and fence.
I am using about 1 oz of XPD per gallon of diesel.
I notice my avaerage milage is now around 17 MPG and that is a mix of stop and go as well as a 30 mile commute to work on a highway each day.
Before XPD I averaged about 15 MPG.
The 6.0 seems to be a lot quieter than before. It definetly starts easier in the mornings. I go to work about 5 AM and the temp in the garage is about 40 with an out side temp around 15 degrees.
Pick up and acceleration seem the same to me.
I will be changing out my fuel filters in the next couple of weeks so I am anxious to see what they look like since using the XPD.
All in all I am very happy with this fuel additive.
2004 F250 Harley Davidson Trim Crew Cab Long Bed
HFCM Water Separator Drain Plug Upgrade
Dieselsite Coolant Filter
Sinister EGR
New (6-16) Ford OEM oil cooler
Shell Rotella ELC coolant
Blue Spring Upgrade
Always Shell Rotella T6 syn 5W40
Edge Insight CTS
2007 Fleetwood Nitrous M-260FS Toy Hauler
Captrick is offline
post #2 of 9 (permalink) Old 01-06-2012, 06:45 PM
Never tried that brand. I used Standyne from day one. Now I am using archoil ar6200 and very happy with it. Notice low end power and a bit of fuel mileage increase. Also a bit quieter.
lenzhotrod is offline
post #3 of 9 (permalink) Old 01-06-2012, 09:03 PM
I've used the Opti-lube additive for over 4 years as preventative for fuel injector lubrication issues. No injector problems to date. I usually use my truck to pull my 5er and don't need an injector problem on the road. My mix ratio is 1 oz to 4 gallons.
2006 F350 SRW King Ranch, Stock, Edge Insight, Coolant filter, Tow Veh for 5er "Jayco Designer". Pulls like there is no tomorrow.
merkair is offline
post #4 of 9 (permalink) Old 01-08-2012, 05:24 PM
I have been using it too. It idles a little more quiet. I didn't really see any mpg increase though...I use the summer blend opti lube and mix about 2 ounces per 20 gallons.
2007 F250 CC Lariat
SCT X3 with Matt's custom tunes
ARP Head Studs
Black Onyx Head Gaskets
Sinister EGR Delete
Sinister Coolant Filter
Powermax Turbo
Edge Insight w/pyro & Fuel PSI
MBRP 4" Straight pipe
Rotella ELC and T6
sly1types is offline
post #5 of 9 (permalink) Old 01-11-2012, 02:18 PM
We better get something to help mpg's! drove through Weimer, Tx Monday and almost fell out of the truck! $4.799/gal @ Chevron! Thought it might be typo on sign, but went on line and checked, sure enough it was the same as posted on the sign!
Ken
2006, F-250 FX4, C/C,Lariat, 6.0 PS w/ Auto & 3:73, Dark Satin Green/Arizona Beige, Zoo-Dad, Diesel Site Coolant Filter, Accu Fab Elbow, Ford-Blue Spring FPR Upgrade, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARP Studs w/ ford HGs, Reman Ford Turbo, New GPs, SCT-ID, EGR delete, Straight Pipe, Nitto Terra-Grapplers AT 18X35's
Muddog06 is offline
post #6 of 9 (permalink) Old 01-12-2012, 08:30 AM
wow I just filled up yesturday at 3.59
2007 F250 CC Lariat
ARP Head Studs
Sinister EGR Delete
Powermax Turbo
Rotella ELC and T6
post #7 of 9 (permalink) Old 12-07-2012, 09:57 AM
TDI Club has a group buy going on Gallon jugs of Opti-Lube. If you looking you can save a little money.
Diesel Fuel Lube ? Save Money on Your Opti-lube Order
ISurvivedNMU is offline
post #8 of 9 (permalink) Old 01-28-2013, 01:29 PM
Optilube XDP proven best!
For any of you who haven't seen this yet, it's worth checking out:
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
Medicine Dog is offline
post #9 of 9 (permalink) Old 02-12-2013, 11:37 AM
Why do people pull that test from the Diesel Place and put it on their site?
