P0102 MAF Circuit Low Input - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 10-18-2011, 06:30 PM Thread Starter
I have and edge insight CTS and it is showing this error. What is it and how hard is it to fix?
2003 CC SRW SB Auto 3.73
Mods:
REAR Air Locker
Kenwood DNX 7140
ISSPRO A Pillar Gauges
Femoto Valve
Edge Insight CTS
dieselhappy is offline
post #2 of 5 (permalink) Old 10-18-2011, 08:13 PM
Bad or plugged MAF sensor, or wiring, or a short in the Vreference circuit. You don't have an aftermarket intake do you?
If it is a bad MAF sensor, it is easy to replace.
Mark
bismic is offline
post #3 of 5 (permalink) Old 10-18-2011, 08:37 PM Thread Starter
no I don't have any aftermarket engine mods. I'll take it to the dealer then should be too expensive I hope?
Mods:
REAR Air Locker
Kenwood DNX 7140
Femoto Valve
Edge Insight CTS
post #4 of 5 (permalink) Old 10-18-2011, 09:55 PM
The MAF sensor is goung to be anywhere from $150 to $220 IIRC
Mark
bismic is offline
post #5 of 5 (permalink) Old 10-19-2011, 12:51 PM
MikeL46's Avatar
My Photos: (14)
Dealer in Vegas quoted me $298. Tousley Ford $128. Simple to change out, just need a Torx driver for the screws.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
115615 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline
