The trouble code P0299 (turbo under boost) has set off the check engine light. I have reset it twice and this morning it came on for a third time. I have talked to a couple dealer tech and they don't know or won't give me any advice over the phone. Both dealers close to me don't like mod's, so I don't want to take it in to them. I have an Airraid intake, banks 6 gun & exhaust. Any ideas on the problem? Or a general idea of something that could be causing it?
2006 F250 PSD CC, SB FX4. Skyjacker 4" lift, 325/60 BF Goodrich tires on 20" Pro Comp Rims, Amp Research Electric Step bars, Harley Bars, Banks 6-gun w/ speed loader, Banks IC, Air Raid intake, Banks Monster exhaust, Viper 5900 remote start, Pioneer Avic-Z1 GPS, DVD, and Stereo head unit, Infinity door speakers, Rockford Fosgate Amps under the back seat, and Rockford Fosgate Sub in the front center seat. I think that is all so far...
Thanks. I will look for that one. This thing is driving me crazy. I only have 10,000 on the truck!
Jacksonville, FL for now, I am from Nashville, TN but don't know when I will be back up that way.
A bad EP input (by sensor or not) will do that as well. It sends data that does not confirm the correct boost so the ECM flags under boost.
Running a tuner mine threw it while I have a bad EP sensor. The Tune is calling for higher boost and the EP is saying the boost ain't there. ECM says "hey, we're not gettig the boost called for". It is, but the EP isn't providing correct data.
Without the tune it hasn't thrown it yet, but the tune calls for more boost. The ECM doesn't know or care how much, just that the exhaust pressure is said to be not reflecting the boost being called for.
With yours being an '06, I don't know what to say. Don't know if it's still using the EP sensor or not. If so, the sensoe is likely corroded as Ford is aware.
__________________ 2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
On my 6.0, P0299 was only cured by replacing the turbo. They tried a coupld of other things - new turbo tube w/blue ends, reseating the entire turbo plumbing - but only the turbo fixed it.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
Thanks for your help guys. A couple of the guys around here also told me that a new turbo was probably needed. Does anyone know a mod friendly dealer in Florida?
