P0470 code, what is it? - Diesel Forum - TheDieselStop.com
Old 01-31-2007, 10:45 AM   #1 (permalink)
What does this code mean? Something to do with backpressure sensor is all I know. Thanks.
(06 Harley Edition F350)
nvrenuff is offline
Old 01-31-2007, 09:27 PM   #2 (permalink)
Re: P0470 code, what is it?
P0407: Exhaust Gas Recirculation Sensor B Circuit Low
(everyday truck)
2004 F250, 6.0l, 4x4, supercab, short bed, 6 speed
(play truck)
1990 F250, 351w turbocharged, Megasquirted, Spearco intercooler, BB GT 42, 5 speed, 4x4, 36x12.50's
dustymoran is offline
Old 01-31-2007, 11:10 PM   #3 (permalink)
So its an EGR problem?
nvrenuff is offline
Old 01-31-2007, 11:54 PM   #4 (permalink)
According to the DTC it is, It is a pretty common occurence.
(everyday truck)
(play truck)
Old 01-31-2007, 11:55 PM   #5 (permalink)
FamilyRide's Avatar
It could be a EP issue since the EP sensor controls the EGR, but depending on calibration you have, that may not meen anything.
It's the charm of DTC's. They don't specify a part that's bad, rather an issue that's occuring. As much as Jr. at Autozone who's trying to sell parts tries to convince you it is. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 02-01-2007, 12:12 AM   #6 (permalink)
I agree , the systems are much more complex than just one part. And the OBD II code is setup to be universal for all vehicles so it would be difficult for their to be a code for every part on every vehicle. Also there is no way for the pcm to monitor every part of the system. It can only tell if the end result from that particular system is not as it should be. Therefore it will alert you that there is something malfuctioning in that system, usually very vaguely.
(everyday truck)
(play truck)
Old 02-01-2007, 01:26 PM   #7 (permalink)
Yup. I see this code a lot on my '97 Jag XJ6. It occurs when the 02 sensor senses emissions very slightly out of spec. Usually happens when the weather is mild and damp. It only takes a millisecond of out of spec conditions to set it off in this car. I would not get overly excited about it.
Of course I could be extremely out to lunch [img]/ubbthreads/images/graemlins/smirk.gif[/img]
2005 F-350 XLT 4x4 SRW Reg Cab long bed 6.0PS tow command
1986 F-250 4x4 woods truck - well broke in 460 gas, they can hear the sucking sound all the way to Texas!
1989 F-250 XLT 4x4 SRW 7.3 IDI soon to replace the '86
robertwoodling is offline
Old 02-01-2007, 03:21 PM   #8 (permalink)
The CEL came on when the truck started one very cold morning (about -16C) and I was in a place where I couldn't plug in the truck. Drove the truck about 500km now and the light still hasn't gone away, will it disappear? If I erase the code to clear my CEL, will this make it so that a Ford tech won't see it in the history when he goes to troubleshoot it? (I don't want to delete it, just make the annoying CEL go away)
nvrenuff is offline
Old 02-01-2007, 03:45 PM   #9 (permalink)
teamroper60's Avatar
I may be wrong, but I believe that unless whatever is causing that code is a continuing problem, after a certain number of key cycles, the light will go away without erasing the code....
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
