p0470 p0069 p0299 p0471 help!! - Diesel Forum - TheDieselStop.com
Old 03-15-2010, 11:49 PM   #1 (permalink)
I just had my quick connect fitting for my HPOP done 1300.00 later just changed the oil & now started it up & the check engine light came on... Just checked for codes and P0470, p0069,p0299, and p0471 all came up.. any ideas?? i dont know if this is something the dealer did when doing the quick connect fitting or if i did it when changing the oil or if it is something entirely different
icecube is offline
Old 03-15-2010, 11:57 PM   #2 (permalink)
joshr33's Avatar
P0069 MAP/BARO Correlation
P0299 Can't locate...
P0470 Exhaust Pressure Sensor
P0471 Exhausr Pressure Sensor Range/Performance
JR
joshr33 is offline
Old 03-16-2010, 12:09 AM   #3 (permalink)
i know the p0299 means turbo/supercharger underboost but i am not sure what is causing all these codes
icecube is offline
Old 03-16-2010, 12:26 AM   #4 (permalink)
teamroper60's Avatar
Since you did not tell us the year of the truck, I can only deduce that it is an 05 based off of the fact you were in for the STC fitting... In looking at the 05 P-code list I have and the codes you are getting, I am wondering if something(s) did not get plugged in good.. I would first check the MAP sensor, VGT solenoid and EBP sensor to make sure the plugs are connected good.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 03-16-2010, 12:26 AM   #5 (permalink)
joshr33's Avatar
Did you knock the VGT Control Valve conection loose?
Hows the oil level?
JR
joshr33 is offline
