p2614 and p2617 codes - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-16-2011, 11:44 PM Thread Starter
I got a 2004 F 250 6.0 Super Duty thats has been giving me fits to get it started it threw two codes p2614 and p2617 when i finally got it started how do i go about fixing them ?
thenutjob is offline
post #2 of 5 (permalink) Old 08-16-2011, 11:58 PM
dieselmac's Avatar
More than likely they have nothing to do with the problem. Extended cranking can cause cam or crank codes. Clear them and they probably won't come back once you have the starting issue corrected.
You should go through this no-start thread and report back your findings. Troubleshooting a "no Start" condition
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #3 of 5 (permalink) Old 08-16-2011, 11:59 PM
Load test batteries and check FICM voltage
Mark
bismic is online now
post #4 of 5 (permalink) Old 09-02-2011, 10:55 AM
powerstroke1392's Avatar
i have the same codes but it wont start... running fine till i killed it at school then 4hrs later it wouldnt start... turns over but wont start... any ideas?
powerstroke1392 is offline
post #5 of 5 (permalink) Old 09-02-2011, 12:54 PM
Did you look at the "No-Start" troubleshooting thread ......... ?
Mark
