Old 03-03-2009, 07:31 PM   #1 (permalink)
Pedal to the Metal no Ooomph
I have an 04 F250 that has developed a new problem. If I jam the accelerator to the floor the engine screams but the truck does not accelerate as it should. The engine also sounds a little 'off' when this happens (and I don't hear the normal turbo whine). If I roll on the accelerator it seems to have plenty of power but if I lay into it the truck falls on its face.
I'm not sure if this is related but I had the truck at the dealer a couple of weeks ago for an Injector Control Module and harness replacement and to repair oil leaks at the rear of the engine. I know the mechanic took the turbo loose because he said he stripped a bolt on it and had to replace the bolt. Is it possible that the turbo wasn't reattached correctly? Today was the first time I really mashed on the accelerator since I got the truck back so I'm thinking it's something that happened at the dealer.
Does anyone have any ideas as to what the problem might be? I'd like to go back to the dealer armed with some knowledge.
Thanks in advance for your help.
2004 6.0 PSD CC Lariat FX4, Tow Package, Air Lift Bags, 2006 Jayco Eagle 325BHS 5th Wheel
KokDiezel is offline
Old 03-04-2009, 01:18 AM   #2 (permalink)
Better get it taken care of while you still have a warranty! Sounds a little like what my 05 is doing..lots of power if you steadily push the throttle..but as soon I mat it..seems to not wanna accelerate. Are you building boost when you mat it?
2005 F-250 4X4 Crew Cab Powerstroke all black
2" Lift
35" cooper all-terrains
4" stainless MBRP
PPE Tuner
1997 F-250 4X4 Ext. Cab Powerstroke white
2" lift
285 Toyo Open Countrys
Ol' Reliable
Straight-Piped
Edge Tuner + a few other mods
mylawn03 is offline
Old 03-04-2009, 08:48 AM   #3 (permalink)
It's going in asap. The service dept. has a parking spot with my name on it. I'm not sure if it's building boost. I don't have a boost guage. How do you tell?
