that is correct the seal in the top of the injector is not replaceable. if they are leaking then you have to replace the entire injector. sux i now esspecially if on your dime. you should be able to tell which seal is leaking buy pulling valve cover and looking for excesive oil leaking thats what we always did at IH dealer. then your only replacing the bad one. usally only the weakist one will blow saving all the others.
2004 Crew Cab shortbox 4x4 lariat
4 inch exhaust soon to be 5
zoodad mod
AutoMeter Autolite II Gauges
SCT x3 programmer with spartan tunes
Real courage is found, not in the willingness to risk death, but in the willingness to stand, alone if necessary, against the ignorant and disapproving herd. — Jon Roland, 1976
