Hello Everybody and a Happy 4th to you all!
I would like to ask for your help in solving some problems as I am not to familiar with diesel trucks!
First my major problem is I recently showed a 2500 HD how to do a burnout properly but then I lost power steering and brakes at low speeds, where its important like turning a corner! I am assuming it is the booster gone bad. Does the booster control BOTH the PS and PB? If so how hard is it to replace or how much should it cost for someone else to replace...if that's the problem!
Second I need to clean my EGR in a serious way! The turbo surges at highway speeds blowing a puff of black smoke with each surge and making a quick noise in the air filter/intake area. The noise is the same as when you are under full throttle and have to let off there is an air intake chatter. Also when idling the turbo will stop spooling (no "whistle"), engine sounds a muffled and when I press the gass, a puff of white smoke comes from the exhaust and the turbo then sounds again! (question on that below) I see the postings on HOW to clean/replace the EGR but not WHERE the darn thing is! Where is the EGR valve? Does this sound like an EGR problem?
Now on to the turbo question! My truck has been compared to a "jet taking off" a "sherman tank" and much more. At idle the turbo is still spooling creating a constant "whistle". The turbo spool is extremely loud! I dig it actually and don't want it to stop!
That being said, this aint my first turbo and most turbo's will have a negative psi at idle where the turbo will not be spooling therefore no noise. Now I think this 6.0 PSD has a hydraulic turbo. Is that normal for this turbo to constantly make pressure/noise? I do not have a boost guage so I am not sure there is psi at idle. I am only assuming because of the "whistle" which comes form the spool which creates boost. I have listened to other PSD's and have not hears such a loud spool so I am a bit concerned about turbo damage and/or to much head pressure wich could damage my head gasket!
Thank you so much for taking the time to read and answer this! I know it is long but I have fallen fast in love with my SD and want to treat it right! it has rapidly become my favourite vehicle to drive and plan on keeping it for a very long time!
THANK YOU ALL FOR YOUR HELP!
My life is always under so much pressure....about 14 psi to be exact! If it aint under pressure and pullin on all 4 corners, I aint drivin it!
2005 Scion xB
(36 mpg for my business)
2005 Highlander (wifes car)
2003 F350 Turbo Diesel
4WD
1999 Yukon Denali
Just 4WD
1990 Celica All-Trac (BLACK)
turbo AWD
1990 Celica All-Trac (RED) turbo AWD
1988 Celica All-Trac (BLACK) turbo AWD
1988 Celica All-Trac (SILVER) turbo AWD
1987 4Runer turbo 4WD
1984 CRX *POS!!!*
