PO336 Error Code - Diesel Forum - TheDieselStop.com
Old 06-07-2012, 10:15 PM   #1 (permalink)
PO336 Error Code
A couple of days ago after driving and stopping my truck when I restarted it the RPM's were very low and it was running very rough. Any attempt to put it in gear or give it more fuel would cause a stall. I turned it off, waited a moment and it restarted and ran fine. No wrench light or anything.
Today, again after a short drive, it did the same thing. This time after several attempts it kept running rough, low RPM's, same stalling. It took ten minutes before it started and ran fine.
I used my Edge Insight to check codes and it had a PO299 (turbo underboost) and PO336 (CKP Sensor A circuit range/performance. From what I can tell the 336 code is the crank sensor, and it seems that the sensor or it's wiring or a connection are the most likely culprit?
Not sure about the underboost code, never saw that before and figure it may have been triggered by the way the engine was running?
It's at the local Ford dealer now.
2005 F350CC DRW, 4x4, 6.0
Ordered late 2004, took delivery 11/2004.
All options ordered except PTO and moonroof.
drysideshooter is offline   Reply With Quote
Old 06-08-2012, 12:02 AM   #2 (permalink)
Feedback Score: 2 reviews
P0299 EP Turbo/Supercharger Underboost EP actual is less than commanded
P0336 CKP Crankshaft position sensor A circuit range/performance Crankshaft sensor circuit
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline   Reply With Quote
Old 06-09-2012, 07:46 AM   #3 (permalink)
Dealer installed a new crank sensor. I cleared the codes and drove the heck out of the truck yesterday and it hasn't put out any codes since. The truck seems like it is starting quicker and has better acceleration. The VGT% seems to be staying in the normal range, and boost seems normal.
Old 06-09-2012, 01:58 PM   #4 (permalink)
My son and I had a competition out of town today. The truck did the same thing. I think I am done with Ford and their crappy diesels.
I unplugged my Edge Insight and the truck started. I don't know if it's a coincidence or if it's possible for an Insight (not a programmer) to cause driveability/running issues?
