Popping noise and feel under floorboard - Diesel Forum - TheDieselStop.com
Old 02-07-2007, 11:35 PM   #1 (permalink)
Does anyone know what this could be? I feel and hear a pop as the vehicle shifts from second to third...driving me crazy.
2005 PSD Excursion 4x4
2005 Excursion, PSD
Limited, 4x4 w/remote start
V Codes, rancho shocks and stabilizer
K&N CAIRS
PS Badges, SuperDuty Chrome Grill
4x2 rear glass struts
285/75/16 BFG AT
texasquail is offline
Old 02-08-2007, 10:00 AM   #2 (permalink)
My Photos: (38)
Re: Popping noise and feel under floorboard
On some of these vehicles, there is interference between the shank of the #2 body bolt and the body of the vehicle. Roll the carpet back from under the brake pedal, remove the black rubber plug, and remove the bolt. Reach under the vehicle and remove the bottom of the #2 body mount so you don't lose it. Do the same on the passenger side of the vehicle, and drive it to see if the noise changes or goes away.
Be careful on the test drive, because without these bolts the vehicle is not compliant with safety regulations.
If the noise goes away with the bolts removed, carefully grind away the sheet metal that is contacting the shank of the bolt, and reinstall the lower mounts, bolts, and rubber plugs. Position your carpet back, and you're redy to go.
What sig?
GregH is offline
Old 02-08-2007, 01:18 PM   #3 (permalink)
Sounds similar to something I'm experiencing, but it's primarily on accelerating from stop, stopping, and general angles enter/exit. Stealership actually found that something in the frame/body that requires some shims... they ordered it yesterday.
2007 F-250 SD Lariat Outlaw PSD
- Undercover Tonneau Cover
- Andersen MFG Rapid Hitch
Diesel Do It!
TrikHed is offline
Old 02-08-2007, 04:23 PM   #4 (permalink)
It could be the sway bar endlinks. It only happened when going over bumps.
2004 F250 True Blue SD 6.0 4x4 auto 3.73 LS
Jarek is offline
