Possibly buying an 05' F250 need some opinions - Diesel Forum - TheDieselStop.com
Old 04-25-2009, 02:37 AM   #1 (permalink)
Here is what I found on the Oasis report. Are these normally reacurring problems or are they pretty much one time problems for every 100K miles or so. The no start problem happened at 100k and the EGR coolant problem happened at 121k the truck has 145k now. Its a good looking truck just worried aobut these two problems. C S VEHICLE IS HARD TO START, SOMETIMES WILL NOT START,Tech Comments:100981 CHECK FOR NO START, HAS NO ICP PRESSURE. CHECK FOR LEAKS IN HIGH PRESSURE OIL SYSTEM, LEAKING AT HIGH PRESSURE PUMP FITTINGS AND RIGHT OIL RAIL. REMOVE TURBO AND REMOVE HIGH PRESSURE OIL PUMP TO REPLACE FITTINGS AT PUMP. ALSO REMOVE RIGHT VALVE COVER AND REPLACE O RING ON HIGH PRESSURE OIL RAIL. REASSEMBLE AND ROAD TEST TO VERIFY REPAIRS. 11.0
CHECK COOLING SYSTEM AND REPORTTech Comments:VERFD CC FOUND COOLANT LEAKING INTO EGR COOLER.REPLACED OIL COOLER RESTRICTED EGR COOLER RUPTURED.EGR VALVE CONTAMINATED.VERFD REPAIR ON TEST DRIVE
gulfcoast is offline
Old 04-25-2009, 11:07 AM   #2 (permalink)
Smiley1's Avatar
They fixed the most irritating problem with the 05 that will leave you stranded. The fittings for those trucks were redesigned. You should not have to worry about that anymore. The oil and egr coolers are a common issue. I installed a coolant filter to extend the life of those components. Thats something you can think about later.
It looks like little work has been done to this truck. I would not be afraid of it.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline
Old 04-25-2009, 11:49 PM   #3 (permalink)
My Photos: (6)
Send a message via AIM to blizzardwarrior7
Yup, looks like the problem areas have been addressed, just dont go putting a tuner on it and you will be fine!
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
