Post your alternator output on your 6.0! - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 03-22-2010, 11:24 PM Thread Starter
I just got home from Cali today, after 33 days away. Apparently I left my GPS on so I arrived back to a dead truck. After jumping it, I utilized the voltmeter function on my Tekonsha P3 to find my output voltage was roughly 11.5 volts, obviously not good! So I hauled @$$ home (110 miles) to go to the dealer and pick up a new alternator. As I was traveling (80+ MPH) I was getting roughly 12.6v out of the truck, and toward the end of the trip I was getting roughly 13.2v. Picked up a new alternator at the dealer, installed it, and on my trip to the girl's house I was getting between 13.6-13.8v underway with the lights on, and at idle it dropped down to 13.4v. Batteries are less than a year old (Diehard Platinums) and the connections all seamed corrosion free. Any ideas? It's a single alternator setup by the way.
04 F350 Lariat, PSD, AT SCSB (the toy hauler) SCT X3 by IDP, Silverline Dual 4" Turbo back exhaust w/no muffler, AFE Stage I, ARP's, Sinister RR Fuel System, 190's, Airdog 150, Alpine W205 DVD player/nav/rearview cam, JL Audio Stealth box w/10" W3v3, Alpine amps x2, Alpine 5x7's all 4 corners, 20% tint, hard tonneau, harpooned, zoodad mod..
The Toys:
2 '91 SHO's, '00 Suzuki GSX-R 750, '03 Yamaha RX-1 Mtn, '14 Yamaha SR Viper XTX-LE
sho91mtx is offline
post #2 of 10 (permalink) Old 03-23-2010, 12:42 AM
teamroper60's Avatar
Your voltage with the new alternator is about on par with mine.. I am going to upgrade to a 160amp large case (the factory is a 110amp small case) though in the next couple of weeks because with the camper on behind me at night, it drops to 13.1 or 13.2..
#43
President and Webmaster
teamroper60 is offline
post #3 of 10 (permalink) Old 03-23-2010, 12:50 PM
MikeL46's Avatar
My Photos: (14)
I son't see anything alarming about your voltages. The alternator output will be low with low batteries. The voltage will go up as the batteries take a charge and need less and less current. I'm not sure your old alternator was bad. It takes a fair amount of current and time to bring the batteries back up.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
115615 miles. 16.65 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
MikeL46 is offline
post #4 of 10 (permalink) Old 03-23-2010, 09:09 PM
my volts when starting after a couple of minutes are 14.8 but go lower after alt heats up with lights on 30minutes later 13.8 to 13.5
turbodieselny is offline
post #5 of 10 (permalink) Old 03-23-2010, 10:02 PM
MikeL46's Avatar
My Photos: (14)
Yes, but you didn't start with a dead battery and need a jump start.
Mike
MikeL46 is offline
post #6 of 10 (permalink) Old 03-23-2010, 10:36 PM
dead batteries ? sho 91 mtx asked to post our volts read the title by the way my batts are original motorcraft build date 2002 november
post #7 of 10 (permalink) Old 03-23-2010, 10:58 PM
prohydroracer's Avatar
My alternator is a month old. 13.9v-14.1v is my typical voltage
2004 F-250 Lariat Ex-Cab Long Box
  • ARP Stud's
  • MBRP 4" Turbo Back
  • Oil and Coolant Bypass Filters
  • SCT w/Custom Tunes
  • Fuel Pressure, HPOP Pressure, Boost and EGT on the A-Pillar
  • Edge Insight monitors EOT, ECT, Tranny Temp
  • Full Security with Remote Start
  • Anti Hi-Jack Device by GLOCK!
prohydroracer is offline
post #8 of 10 (permalink) Old 03-25-2010, 04:51 PM
For the last month my morning start ups were taking a little longer than usual and just didn't sound right. Took an alternator reading last week and it was 13.8v. Battery reading was 11.4v (with engine off). My Motorcraft batteries were purchased Jan '08. Took my truck to Ford Dealer this last Saturday with the receipt in hand. An hour later service advisor says truck is ready the batteries were defective and they gave me two new batteries under warranty.
2004 Superduty CC 4x4 6.0 Lariat 70k miles
Oil cooler / EGR cooler removed and replaced March 2010
PSDinAZ is offline
post #9 of 10 (permalink) Old 03-25-2010, 07:14 PM
dikkstarr's Avatar
Mines at 12.6 before start up, then hangs at about 11.7 until the glow plugs click off. After that my voltage jumps back to 12.5, then slowly ramps up to 14.1 for about 5 minutes, then drops and stays around 13.1 to 13.4 the rest of the time.
2004 F-250
dikkstarr is offline
post #10 of 10 (permalink) Old 03-25-2010, 08:21 PM
Hear is some real good reading about alternator's.
I was have issues with mine and got a 200 amp HD large case and my truck LOVE'S it.
http://thediesel garage.com/forums/showthread.php?t=92173
work&play is offline
