power loss 6.0 - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 12-19-2011, 05:18 PM Thread Starter
power loss 6.0
Hi,
I'm a newbie with diesel and any feedback would be greatly appreciated, thank you.
I have a 6.0 and a few weeks back I stepped on it, acceleration was fine it was when I stepped off the gas pedal and then tried to re-accelerate there was a bad bog I had to feather the gas pedal to bring the rpms up because it seemed like it wanted to stall almost like it was choking, there was also a sound? ( the only way I can describe it is similar to having a stone in your hubcap, would that be the turbo?)after that everything was fine till yesterday when I had a cold start and drove it 200 feet 3x's and had to shut down each time, the second last start it wouldn't start just turning over, I had to step on the gas pedal before it started.
fatboywpg is offline
post #2 of 5 (permalink) Old 12-19-2011, 06:23 PM
hottip's Avatar
I would be thinking that its the EGR valve.
2005 Lariat 6.0 LWB fourx4 3:73 Silver Metalic, Heated Captains chairs, Tow Command, Reverse Sensor, Intergrated Brake Control, Power Rear Window
MBRP Turbo back exhaust, Glasstite Canopy, billet grill, 162+
Scan Gauge 2
Bear - Flat Coated Retriever
2000 HD Road King
1998 Campion 542 Explorer fishing machine
The difference between stupidity and genius is that genius has its limits.
hottip is offline
post #3 of 5 (permalink) Old 12-19-2011, 08:21 PM Thread Starter
Thanks Hottip I will try that
post #4 of 5 (permalink) Old 12-19-2011, 08:32 PM
Feedback Score: 2 reviews
As stated start with the egr these guys will show you how it is done they are a blast
6.0L power stroke egr repair - YouTube
Then you may have to clean the turbo the unison ring may be frozen
DTS Articles - Turbocharger Reconditioning
Need to add cetane boost to the fuel to keep things working and clean.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #5 of 5 (permalink) Old 12-20-2011, 08:56 AM Thread Starter
Thanks 2 Stroker I will start with that
much appreciated
