Old 11-05-2009, 06:18 PM   #1 (permalink)
PowerSteering Fluid, Type ?
I just finnished cutting out a rusted section of p/s cooling lines , replaced with good quality rubber.
I looked in the owners man , and the supplimental little 6.o book in the glove box. Did not find the type.
I put in 2qts of type F , to test my "fix" out.
thank you , 24hrsparkey
Stock 03 250 SD 2door 4x4 p/u
6.0 June 03 Build Date
87,000 miles
E-017 flash
Muff Delete pipe , otherwise Stock
AND
2000 f350 ccab 4x4 , nice BIG truck that lumbers right along. Only 100,000 miles on it.
24hrsparkey is offline
Old 11-05-2009, 07:25 PM   #2 (permalink)
I used Mercon V synthetic. Works really good and meets specs.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident
2007 Jazz 5er, 11k
173rd Airborne
69cj is online now
Old 11-05-2009, 09:17 PM   #3 (permalink)
+1 for Mercon V
Mark
'06 F250, CC SB ESOF FX4 Lariat 3.73LS, 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto valve; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & Britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
bismic is offline
Old 11-05-2009, 09:23 PM   #4 (permalink)
opps . It figures it takes the special V that is non existant exept at the dealer 40m away.
I probl should drain it and put in the propper V as time permits.
87,000 miles
E-017 flash
AND
Old 11-05-2009, 09:51 PM   #5 (permalink)
rock_doctor's Avatar
The type F should be fine. It isn't a C-4/C-6 but it should not make a difference. Where did you find a quart of type F? I am using Mercon V because i have a couple quarts left over from my 2002 Excursion....
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 11-05-2009, 11:34 PM   #6 (permalink)
Matt0987's Avatar
The owner's manual reads;
CHECKING AND ADDING POWER STEERING FLUID
Check the power steering fluid.
Refer to the scheduled maintenance
guide for the service interval
schedules. If adding fluid is
necessary, use only MERCON ATF.
If you need an owner's manual you can get it from;
https://www.flmowner.com/servlet/Con...OwnerGuidePage
'03 Excursion, 7.3L, 4X4, 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Bilstein shocks, Rancho steering damper. Airlift 5000. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter, 2m-70cm Yaesu ft-8500.
Matt0987 is offline
Old 11-06-2009, 04:01 AM   #7 (permalink)
YA , manual also says only use straight mercon in trannies too and look how long that lasted Just use whats in your tranny. You do know whats in your tranny ? Hope to GOD it aint type F !! P.S. I'm trying to be funny, not a JERK
2001 X Limited 4x4 PSD,F5 DP Tuner,Ford AIS intake, Magnaflow 4in.,Autometer GS 3pod pillar,BFG M/T KM 285x75x16,X-codes w/ blocks,6.0 cooler,eng.coolant filter,Hellwig sway-bar,RS9000X,Dark Satin Green,XM radio,Yakima MegaWarrior Rack. 1973 K5 Blazer 383stroker,TrickFlow alum.heads,Crower forged rods-roller lifter cam-roller rockers,Keith Black 10.5:1,Doug Thorley tri-y,MSD,ARP,Q-jet,on 1 ton axles 2003 Mastercraft X9
boomboom is online now
Old 11-06-2009, 09:20 AM   #8 (permalink)
I know all about Mercon SP only in the 44B auto transmission , from this site , changing the little aux filter , and replacing $220 worth of rusted trans cooler lines. By the way that job was a biatch.
Back to my power steering re fill after repairing those rusted lines.
I put Napa ATF recomended for vehicles requiring DEXTRON3 or Mercon Fluid. Not Recomended where Ford M2C33-F is required. Only thing i had. Now my brake pedle feels different , even after 50+ miles and i was wondering if my fluid choice did it.
As time permits in between fixing other stuff on this truck , YES i'll probl drain and re fill with the correct V fluid , now that i know that is what is required.
thank you . 24hrsparkey.
Edit . I seem to even confuse myself on these fluids, sorry.
Did I use the correct stuff or not ?
87,000 miles
E-017 flash
AND
Old 11-06-2009, 11:30 AM   #9 (permalink)
I bought my mercon V at Pep boys. I would think if they have it that AZ, Kragen or Napa would have it.
2007 Jazz 5er, 11k
173rd Airborne
69cj is online now
Old 11-06-2009, 11:41 AM   #10 (permalink)
JW350's Avatar
My Photos: (29)
I used Valvoline DEX/MERC ATF when I flushed my power steering fluid. It's about $4/qt at your local auto parts store.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, 37x13.5x17 Tires, 4.88 Gears, Turbo-back Exhaust, Gauges, Air Bags...
JW350 is offline
Old 11-06-2009, 12:50 PM   #11 (permalink)
If you put DEX3/MERCON in you are good to go, If type F was used you might want to change it. You do not need MERCON 5
Old 11-06-2009, 01:27 PM   #12 (permalink)
OK .
The Manual says Mercon ATF , for adding or re fill .
So far there are way too many kinds of red stuff for me to mentally grasp. I'm not the britest bulb on the tree.
Which flavor of Mercon is assumed to being the correct flavor in the manual stating " Ues only Mercon ATF" for power steering
Mercon SP
Mercon 5
Mercon
Dextron 3
Does Mercon indicate synthetic , or the designation abc,123 ect ?
87,000 miles
E-017 flash
AND
Old 11-06-2009, 02:07 PM   #13 (permalink)
Originally Posted by 24hrsparkey View Post
OK .
Mercon SP
Mercon 5
Mercon
Dextron 3
I know the SP is syn. and the V can be bought in syn. or non-syn.
2007 Jazz 5er, 11k
173rd Airborne
69cj is online now
Old 11-09-2009, 03:10 AM   #14 (permalink)
Mercon or dexronIII/mercon are none synthetic and is what is recommended for your PS pump in owners manual. sorry I missed your last question on friday.
Old 11-09-2009, 02:59 PM   #15 (permalink)
Not a probl sir ,, Hell i confused myself on the diff types !!
In all honesty i put in 1 Type F ( old from my garage ) and 1 mercon/dextronIII.
It works , but i agree NOT the best of mixing choices. As time permits i'll buy several Mercon/dextronIII and flush and fill with that manual recomended fluid.
I do thank you all for your help.
24hrsparkey
87,000 miles
E-017 flash
AND
