The Pro Techs will laugh at this visual but here goes - Diesel Forum - TheDieselStop.com
Closed Thread
Old 11-14-2009, 02:42 PM   #1 (permalink)
Hi-Lift Product Comparison - Which Hi-Lift Product is right for me? | Hi Lift Jack Company
Maui Stroker is offline
Old 11-14-2009, 03:35 PM   #2 (permalink)
chuckster57's Avatar
I am old enough to remember when a new car came with that style of jack in the trunk with a FULL SIZE spare tire.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 11-14-2009, 05:44 PM   #3 (permalink)
Matt0987's Avatar
Yep, I've changed a few tires on the family car with that type of jack.
Dangerous type of jack though. The car is up, someone bumps the car or the kids start fighting inside of the car and BAM! the car is on the ground, the brake drum is bent. And, if you are lucky, the one changing the tire is not hurt.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 11-14-2009, 07:09 PM   #4 (permalink)
rock_doctor's Avatar
that is because the cars had full frames, real bumpers and using a jack didn't require a degree in mechanical engineering.... I tried to change a tire on a volvo and the jack actually fit into a recessed notch in the center of the car. To change a tire you actually had to lift up the entire side of the car... Which of course did not work. The car twisted and fell off the jack. Luckily, a guy with a floor jack came by and jacked it up. So that is my comment to the original poster...Go get yourself a nice floor jack with a case and go with that. He had a very nice craftsman 3ton capacity in a case. Remember jack up the axle not the body.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 11-14-2009, 08:30 PM   #5 (permalink)
bugman's Avatar
My Photos: (18)
These are not the same type of jack that use to come with the cars years back. These jacks are intended for off road and farm use and every truck or 4 wheel drive vehicle that goes off road should have one. The ones that you are thinking of that came with cars were made out of stamped steel with a separate base plate that the upright fit into. Then you used the lug wrench to jack up the car by the bumper. On some of them the jack would fit into a slot into the bumper and others would fit under the bumper and then brace itself on the bumper itself. If you tried to use an old bumper jack for what a High Lift jack would do it would fold itself in two.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-14-2009, 08:35 PM   #6 (permalink)
I'm one of the lucky ones. I had an 87 GTA transam fall on me. while I was taking the cross member out from the transmission.
It fell off the jack stands when I pulled the thing that ran between the tail shaft and the rear end. I think it's purpose was to prevent wheel hopping or something. either way those cars have no ground clearnce.
21xdbullet is offline
Old 11-14-2009, 08:51 PM   #7 (permalink)
Originally Posted by 21xdbullet View Post
I'm one of the lucky ones. I had an 87 GTA trans am fall on me. while I was taking the cross member out from the transmission.
It fell off the jack stands when I pulled the thing that ran between the tail shaft and the rear end. I think it's purpose was to prevent wheel hopping or something. either way those cars have no ground clearance.
ouch, i had an 88 GTA, that was a nice car...
i suspect those who commented are familiar with the high lift jacks. Like i said i think a good floor jack is the way to go. If you think you may need to use it to jack/wench yourself out of a hole then consider getting a nice frame mounted electric wench. If you are sold on the high lift then get the strongest one you can find. Remember the truck weighs 7k plus pounds. Go with the mid if you are not a major off-roader, if you are then get the best.
Closed Thread
