Question ??? - Diesel Forum - TheDieselStop.com
Old 03-21-2009, 09:59 AM   #1 (permalink)
DGB
Question ???
Hi Everyone,
Been a member here for almost four years but I have mostly been an occasional lurker. So, before anyone starts to chew me out because this question has been answered here a nimber of times in the past, keep in mind this is only my 5th post.
My question is what causes farting. In case I can't say that here then let's call it pharting. Where does it come from? I have had my truck in for warranty work quite a few times and everytime they have worked on it they ended up changing the TC with exception of the time the head gasket blew and they changed the head bolts on both sides. On every occasion except the head gasket one of the symptoms was pharting.
Darkside Dave
'03 6.0L 4WD dually crew cab F-350
www.daveboley.info
www.darkside53.info
DGB is offline
Old 03-21-2009, 11:21 AM   #2 (permalink)
Originally Posted by DGB View Post
Hi Everyone,
Overboost. With a VGT turbo, there is no waste gate or blow off valve. In a high boost quick drop off, the extra air has no place to go, except back down the intake.
OMC
OMCUSNR is offline
Old 03-21-2009, 07:34 PM   #3 (permalink)
your turbo is sticking it should barley do it.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 03-21-2009, 08:35 PM   #4 (permalink)
My Photos: (6)
Send a message via AIM to blizzardwarrior7
Exactly what OMCUSNR said...On the 7.3s, or any engine with a wastegated turbo for that matter, the purpose of the wastegate was to relieve excess boost...With a VGT turbo such as the one on the 6.0, when you have the foot on the gas, or accelerate hard, and than let off of it, that extra pressure has no where to go, thus making that farting noise...Some people will tell you its bad for your turbo, its not.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
Old 03-21-2009, 10:04 PM   #5 (permalink)
RatherBNtheWoods's Avatar
I don't follow. Why don't the pressure go into and through the engine just as it was a split second before? It's not like there is a throttle plate that closes or something to keep the what's called "excess" from going on about it's normal merry way.
I thought the "farting" was because of a sensed overboost condition by the PCM because something is amiss. The PCM, upon detecting the overboost, releases the oil pressure on the VGT suddenly which allows the pressure to backflow through the airfilter making a whoose(fart) sound. Normally the PCM raises and lowers the oil pressure on the VGT smoothly to increase or decrease boost pressure, so it doesn't make the noise normally.
Anyway, farting is bad umkay. If it's farting, umkay, someting is amiss and needs to be looked at, umkay.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
