Question about alternator/charging........ - Diesel Forum - TheDieselStop.com
Old 05-05-2005, 10:27 PM   #1 (permalink)
Guys,
I noticed that when I first start my 6.0, based on the speed of the wipers, windows, and blower fan, that the alternator doesn't kick in for several seconds. I suspect this because after several seconds, which can range from 5-20, I can notice the speed of the wipers and windows and fan speed suddenly increase to a "normal" level.
Is this normal, or should the alternator kick in immediately once the engine turns over?
I'm not having any problems - the truck is running fine and I have no problems starting.
Thanks,
CMOS
2004 Ranger SCAB
Shopping for 99-2002 7.3 CREW
CMOS is offline
Old 05-05-2005, 10:39 PM   #2 (permalink)
My Photos: (21)
Re: Question about alternator/charging........
It's normal CMOS. The glow plugs will pull down the system voltage for up to 120 seconds.
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 05-05-2005, 11:21 PM   #3 (permalink)
The glow plugs are still drawing current even after the dash indicator icon goes out?
CMOS
2004 Ranger SCAB
CMOS is offline
Old 05-06-2005, 12:14 AM   #4 (permalink)
Yep. They run for up to two minutes after you turn the truck on.
tvsjr is offline
Old 05-06-2005, 08:08 AM   #5 (permalink)
Thanks.
CMOS
2004 Ranger SCAB
CMOS is offline
Old 05-06-2005, 08:54 AM   #6 (permalink)
dbennett48's Avatar
The alternator is computer controlled and comes on when all of the parameters of the computer's programming are met. It takes a bit. The glow plugs are the biggest drain on the system, as noted.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
