Question about torque shift transmission? - Diesel Forum - TheDieselStop.com
Old 08-04-2009, 10:49 AM   #1 (permalink)
KingKong's Avatar
My Photos: (11)
Over the weekend I was pulling my Camper and forgot to put the transmission in tow haul mode I was running interstate 65 or so and stop and go traffic on level ground not much hills on the run. Question is Does it hurt anything running pulling around 8000# out of tow haul mode?
07 F-250 6.0 L CC XLT 4x4 Red Addons: ARE Cover, WheelSkin Cover, PML Rear axle Cover, Dieselsite Coolant Filter, C-better Mirrors,Gauges Isspro Fuel press. Trans Temp. EGT gauge. Gauges from Diesel Manor. Edge Insight CS (For EOT & ECT)
04 F-250 6.0 L CC XLT 4x4 White Buy Back
...... 06 Jayco Travel Trailer 32'
KingKong is offline
Old 08-04-2009, 10:54 AM   #2 (permalink)
You didn't hurt anything. All the tow hall feature does is gear down for you and give you a few more rpms before it upshifts.
2005 F250 CCSB FX4 Lariat Lux Pkg, Banks Monster Exhaust, Sinister EGR Delete kit, ARP Studs, Dieselsite Coolant Filter, Edge Insight Gauges, Autometer Phantom II Fuel Pressure Gauge, Blue spring upgrade, 6.4 Fuel Banjo Bolts, Upgraded HPOP fitting, Innovative Diesel SCT X3, Red Head steering box.
champelite210 is offline
Old 08-04-2009, 11:57 AM   #3 (permalink)
sergeantnic's Avatar
Agreed..
I tow my boat which is around 6,000 pounds and the only time I use tow haul mode is when I coming up to a stop light. I hit the button so the truck does some engine braking for me. Other than that, I haul about 75mph on the interstate with the cruise control set.
sergeantnic is offline
Old 08-04-2009, 12:02 PM   #4 (permalink)
KingKong's Avatar
My Photos: (11)
I did not even think about it until I pulled in to my driveway where I take it out of tow haul because for some reason it downshifts really hard there don't know why it does it there and only there but it does.
KingKong is offline
Old 08-04-2009, 03:13 PM   #5 (permalink)
69cj's Avatar
I tow an 11k dry weight 5er with the cruise on in hi gear no problem. I use the tow command when I hit heavy grades or the mts.
69cj is offline
