Questions on KAM - Diesel Forum - TheDieselStop.com
Old 09-09-2006, 01:40 PM   #1 (permalink)
Questions on KAM
What parameters make up keep alive memory. If the negative battery terminals are disconnected to clear KAM, will preset radio stations be erased? Is KAM continuously updated while driving, or is it a fixed set of parameters? If fixed, are they programed in with PCM updates? Thanks for your help.
Rick
2004 F350 KR,LB,SRW,4X4,18" wheels - Loaded,
Added: Line-X, Isspro EV gauges, Prodigy, C-BETR mirrors, Huskey liners, PIAA-1500 Back-Up, Rancho 5406, RETRAX, Fumoto, XM Radio
RootDoc is offline
Old 09-09-2006, 02:51 PM   #2 (permalink)
ritschner's Avatar
Send a message via AIM to ritschner
Re: Questions on KAM
There is a fixed set of parameters that is the actual programing of the PCM that makes the truck run, these have to actually be programed into the PCM. Then there are the learning parameters that constantly adjust while you are driving, I would describe them more as fine tuning of the programed parameters that take into account the driving style and other variables. These learned parameters, trouble codes, and other information are kept in the PCM unless power is interupted in the keep alive circuit. Disconnecting the batteries will erase these parameters and your radio stations as well. However there is a fuse(no 10) in the fuse box under the hood labeled PCM Keep Alive Power that when removed will do the same thing without losing radio or other settings.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
Old 09-09-2006, 05:06 PM   #3 (permalink)
Upon disconnecting both of my batteries, to clear KAM, my stock radio maintains its presets. But, I do like the idea of that fuse - tks!
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
4x4Mark is offline
