Quick question on HG's/ cooling - Diesel Forum - TheDieselStop.com
Old 10-31-2012, 10:33 AM   #1 (permalink)
Hello all, I think my HG's went out again. I was told that a failed water pump can cause coolant to puke out of the degas bottle. So, question, is that true? I also have a coolant leak that looks to be coming from the water pump. The truck has been parked ever since this started. Last time my HG's went out i had a lot of white smoke. This time there is none. So my main question is can a failed water pump make coolant puke out of the degas bottle causing me to believe that my HG's went out?
Thanks for your replies, Dan
2005 F-350 Harley Davidson CC LB Loaded w/6.0
113000 miles.
8" Fabtech lift with Dirt Logic 4.0 shocks.
37*14*r18 Nitto Terra Grapplers.
18" raceline wheels.
4" MBRP turbo back straight pipe with 6" tip.
SCT tuner custom tuned by Eric.
Optima Red top's 1/12
High Idle Mod 4/12
Garret Powermax Turbo 9/12
ARP studs 9/12
New Head gaskets 9/12
EGR delete 9/12
oil cooler 9/12
new intercooler 9/12
fuel spring upgrade 9/12
Sinister coolant filter 9/12
water pump 12/12
fan clutch 12/12
New Head Gaskets 3/13
Dummy Plugs 3/13
Standpipes 3/13
STC fitting 3/13
New oil cooler 3/13
http://www.youtube.com/watch?v=s9NhrURNsWs
I'd rather push a ford then drive a chevy!!
Big Dan P is offline   Reply With Quote
Old 10-31-2012, 03:16 PM   #2 (permalink)
nitrogen's Avatar
very few cases where HG's result in white smoke. generally that is coolant going into the intake from a bad egr cooler. puking from combustion gas getting into cooling system and overpressuring it is more likely a sign of bad HG's.
before I ASSUMED head gaskets were/are the issue I would want to do some basic testing. suspicious wet water pump, pressure test the system with some UV dye and prove it. some of the older engines had issues with the pump impeller getting loose on the shaft and freewheeling. if the coolant is not circulating properly boiling can certainly occur which will result in coolant being forced out.
nitrogen is offline   Reply With Quote
Old 10-31-2012, 11:22 PM   #3 (permalink)
Thank you Nitrogen for the reply. Good point on the white smoke thing I'm an idiot lol! I'll rent the pump and do a pressure test when I wake up today. Does anyone know that if I hook up a gauge to a tee at my degas bottle to test for a headgasket leak, if head gaskets are the only thing that can cause pressure in your system? Because I am thinking, if it is my water pump not circulatuing and causing coolant to flash boil, wouldn't that also pressurize the system? Thanks for any more replies, Dan
113000 miles.
High Idle Mod 4/12
ARP studs 9/12
EGR delete 9/12
oil cooler 9/12
water pump 12/12
fan clutch 12/12
Dummy Plugs 3/13
Standpipes 3/13
STC fitting 3/13
New oil cooler 3/13
Old 11-01-2012, 11:48 PM   #4 (permalink)
Check youtube as there is one that shows how to find what side HG has a leak if there is one.
bigredak is offline   Reply With Quote
Old 11-02-2012, 11:28 PM   #5 (permalink)
Ok thanks. I'll take a look at it. Do you happen to remember the name of it? Thanks, Dan
113000 miles.
High Idle Mod 4/12
ARP studs 9/12
EGR delete 9/12
oil cooler 9/12
water pump 12/12
fan clutch 12/12
Dummy Plugs 3/13
Standpipes 3/13
STC fitting 3/13
New oil cooler 3/13
Old 11-06-2012, 09:25 AM   #6 (permalink)
Get a YouTube account and subsribe to these two channels and get good how to videos.
This one has the test for what side may have a cracked head or injector cup.
6.0 powerstroke diesel fuel in the coolant - YouTube
This is to test HG or if it is EGR cooler. You can make your own tester using auto/hardware store parts.
HEAD GASKET TEST for 6.0 POWERSTROKE - YouTube
Old 11-07-2012, 05:05 PM   #7 (permalink)
is headgaskets the only thing that will pressurize the cooling system?
04 oilburner is offline   Reply With Quote
Old 11-08-2012, 10:10 AM   #8 (permalink)
A ruptured EGR cooler or bad engine oil cooler could as well, but the effects will be much less pronounced than with a blown HG.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, Warren Diesel 175cc injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - shooting for the 12s!
'02 WRX - Outback rear disc swap, EBC green pads, pillar vane front rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline   Reply With Quote
Old 11-11-2012, 10:42 AM   #9 (permalink)
To get the fast high pressure like in the video it can also come from a crack in the block or a head. I once worked on an engine that had only water running in it and it cracked the block when cold weather hit it. It would start and ran fine when cool, but at normal engine temp it blew water out. An engine that gets too hot can crack or warp the block or head to let the combustion gases into the coolant system. So be sure to have heads checked for cracks when off.
Old 11-24-2012, 04:26 PM   #10 (permalink)
Just got back in town from vacation. I'll definitely subscribe to those pages. I've been out of town for approximately 3-4 weeks. Truck has been sitting for at least 4 weeks, possibly 5. Went to start it up today to make sure batteries stay charged, and the wierdest thing happened. Truck ran perfect. Didn't overheat. Took it for a ride around the block, romped a little on it, and never overheated. Didn't overflow out of degas bottle or anything. It ran for a total of about 45 minutes. Before, it was overheating within 15 minutes of being turned on. Now I am lost. It is back parked now. I'm driving my F-150 around. What do you guys think. I am now thinking that it maybe is the water pump that is going bad and intermitally working? I am probably just being optimistic though. Thanks for the replies, I appreciate any and all input, Dan
113000 miles.
High Idle Mod 4/12
ARP studs 9/12
EGR delete 9/12
oil cooler 9/12
water pump 12/12
fan clutch 12/12
Dummy Plugs 3/13
Standpipes 3/13
STC fitting 3/13
New oil cooler 3/13
Old 11-25-2012, 12:28 PM   #11 (permalink)
I didn't notice you had studs when responding to your last post. It is unlikely that you have HG problems with studs and new Ford gaskets properly installed. Not impossible mind you, but unlikely.
I'm liking the water pump for your woes.
Old 11-25-2012, 11:27 PM   #12 (permalink)
Man, that would be fantastic!! Still not going to get over optimistic lol. But, the way I'm looking at it is, either way I have to do water pump, so why not do that first. Thank you everyone for your replies. I will order the water pump from tousley probably tomorrow. As soon as it comes in I'll put it in. I'll let you guys know the results.
Again, Thank you very much!! Dan P
113000 miles.
High Idle Mod 4/12
ARP studs 9/12
EGR delete 9/12
oil cooler 9/12
water pump 12/12
fan clutch 12/12
Dummy Plugs 3/13
Standpipes 3/13
STC fitting 3/13
New oil cooler 3/13
Old 11-26-2012, 06:06 AM   #13 (permalink)
A failed water pump can make it puke (anything that can make it overheat can make it puke), but you would see very high coolant temperatures w/ a bad water pump. Please post the coolant temps you have (and the oil temps). If you don't have gauges, then you need to get some.
How full do you keep the degas bottle? Since you have a coolant leak, have you been filling it with water or a 50/50 mix?
The early model years had water pumps w/ impellors that broke or came loose. the later ones - not so much. An intermittant water pump does not sound likely to me.
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD Billet WaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline   Reply With Quote
Old 11-26-2012, 11:58 PM   #14 (permalink)
My coolant temp got up to 250-255 when I realized they were that high I stopped driving and had it towed home. At that time my oil temp was 218-225. I keep my Degas bottle filled to the minimum line. I filled it back up with Ford gold, which I know is crap, and plan on flushing out when i do my water pump.
113000 miles.
High Idle Mod 4/12
ARP studs 9/12
EGR delete 9/12
oil cooler 9/12
water pump 12/12
fan clutch 12/12
Dummy Plugs 3/13
Standpipes 3/13
STC fitting 3/13
New oil cooler 3/13
Old 11-27-2012, 12:56 AM   #15 (permalink)
As bismic stated, highly unlikely to have an "intermittent" water pump issue. When you replace the water pump, I would recommend replacing the thermostat as well. It is cheap insurance, they can be intermittent, and is good preventative maintenance while cooling system is empty. One other thing I would suggest is testing pcm for any fan codes. If there are no codes, I would still run the fan test, to verify it is reaching proper operating speed. I have seen numerous fan clutches that do not reach full speed and cause overheating issues, along with A/C concerns in warm weather...you may want to check this before removing water pump. If the fan clutch is not operating properly, you can replace it while fan is off while do water pump. A fan clutch may give you an intermittent issue depending on ambient temp and how hard you were working engine.
djshum is offline   Reply With Quote
