Quick question on HG's/ cooling - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-27-2012, 01:29 AM   #16 (permalink)
Originally Posted by Big Dan P View Post
My coolant temp got up to 250-255 when I realized they were that high I stopped driving and had it towed home. At that time my oil temp was 218-225. I keep my Degas bottle filled to the minimum line. I filled it back up with Ford gold, which I know is crap, and plan on flushing out when i do my water pump.
Evans Coolant eliminates cavitation of conventional coolant at 250F
With conventional coolant used with water you have pockets of steam
in the head passages wich cause boilover and head warpage and failure.
with Evans the coolant will not seperate from the jacket or cylinder liner wich always transfers heat into the coolant and into the radiator.
Giving you more time behind the wheel than under the hood.
Javier
1988 F250 dually All New 7.3 IDI, Banks Sidewinder.
C-6 with GearVendors overdrive 3.55 ring gear
Synthetic SAE 10W-30/SAE 30 Heavy-Duty Motor Oil,
Evans NPG coolant.
AMSOIL ATF in the transmission, AMSOIL gear oil in the diff.
20MPG city 25/28 hwy
IDIABUSE is offline   Reply With Quote
Old 11-27-2012, 06:01 AM   #17 (permalink)
There is a guy on FTE w/ 580k miles on his 6.0L and he used Ford Gold its whole life. He has it apart and is METICULOUSLY rebuilding it. It did not have any cavitation damage or head warpage. So it seems safe to say that the Gold can be made to work just fine - properly maintained. That being said, if folks want to feel better w/ a change - power to them (I know I succombed to all the talk and put in the ELC Ultra - I like its chemistry).
Big Dan P -
The coolant and oil temps are "out of whack". I would sure follow djshums advice. With temperatures that hot, I would be hard pressed to say that you had head gasket issues. The most important thing to do first is solve your cooling issues.
I would also consider swapping the coolant and oil temp sensors as a test to see if one (or both_ are bad. Another test is to see if they both read the same as the ambient temp on a cold engine (after sitting all night).
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD Billet WaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline   Reply With Quote
Old 11-27-2012, 01:25 PM   #18 (permalink)
Good idea. Ambient temp was mid 90's here in FL. I'll do the fan test first. As you stated would be much easier to do it while doing the water pump. When I ordered from Tousley, I ordered everything that was in the water pump category including thermostat and all the new gaskets. I'll do the fan test later today. Thanks for the input, Dan
2005 F-350 Harley Davidson CC LB Loaded w/6.0
113000 miles.
8" Fabtech lift with Dirt Logic 4.0 shocks.
37*14*r18 Nitto Terra Grapplers.
18" raceline wheels.
4" MBRP turbo back straight pipe with 6" tip.
SCT tuner custom tuned by Eric.
Optima Red top's 1/12
High Idle Mod 4/12
Garret Powermax Turbo 9/12
ARP studs 9/12
New Head gaskets 9/12
EGR delete 9/12
oil cooler 9/12
new intercooler 9/12
fuel spring upgrade 9/12
Sinister coolant filter 9/12
water pump 12/12
fan clutch 12/12
New Head Gaskets 3/13
Dummy Plugs 3/13
Standpipes 3/13
STC fitting 3/13
New oil cooler 3/13
http://www.youtube.com/watch?v=s9NhrURNsWs
I'd rather push a ford then drive a chevy!!
Big Dan P is offline   Reply With Quote
Old 11-27-2012, 09:37 PM   #19 (permalink)
Excuse me for posting so much. I am computer illiterate . I didn't realize another page had been started. Today, I erred on the side of caution and ordered a new fan clutch this afternoon. Haven't done the test yet because I got called into work. I figure that as much as I have in the motor already, what will another $285 hurt lol. I will look into any codes in the A.M. also. I will check the ambient temps on my gauge in the morning when I get home from work to see if they are out of whack. If they are, then I will be getting back onto Tousley to order new coolant and oil temp sensors. I deeply appreciate all the input from you guys. That's why I consider this one of the best forums out there!! Thanks again, Dan
113000 miles.
High Idle Mod 4/12
ARP studs 9/12
EGR delete 9/12
oil cooler 9/12
water pump 12/12
fan clutch 12/12
Dummy Plugs 3/13
Standpipes 3/13
STC fitting 3/13
New oil cooler 3/13
Old 12-10-2012, 09:42 AM   #20 (permalink)
In conclusion
Hey guys, I put in the new water pump, thermostat, and fan clutch the other days. Glad to say that I am not overheating anymore. I think it was a mixture of the water pump and the fan clutch. Since replacing them I haven't even got hot enough for the fan to kick on. I would like to thank all of you that took the time to help me figure this out. Thank you, Dan.
113000 miles.
High Idle Mod 4/12
ARP studs 9/12
EGR delete 9/12
oil cooler 9/12
water pump 12/12
fan clutch 12/12
Dummy Plugs 3/13
Standpipes 3/13
STC fitting 3/13
New oil cooler 3/13
