Quite then loud..... - Diesel Forum - TheDieselStop.com
Old 09-20-2005, 02:23 PM   #1 (permalink)
ZR1PETE's Avatar
I have a 2005 King Ranch CC dually with a 6.0 diesel
the thing I have been noticing is at idle the diesel engine
sound would get very quite then get louder then get quite again.
and this would cycle like this several times. I also would hear this
several times while driving at a steady rpm. What might be happening? Is there anything I should worry about? Also there are no engine codes or any driveability issues at this time. And I also have the original computer program as new, with no reflashes. BTW truck is completely Stock, no aftermarket anything.
Thanks for any help you might have. [img]/ubbthreads/images/graemlins/cool.gif[/img]
ZR1PETE is offline
Old 09-20-2005, 03:11 PM   #2 (permalink)
Send a message via ICQ to agdodge4x4
Re: Quite then loud.....
I have noticed this on mine and several others. It seems like it gets loud when the AC compressor kicks in. I assume its a fuel injector thing of some kind. Normal as far as i can tell. I am pretty sure i know what you are talking about.
Jason
Texas A&M University
Class of 2002
2005 F-250 4x4 (FX4), Lariat Arizona Beige/Black two-tone, 5 spd Auto, 6.0L.
agdodge4x4 is offline
Old 09-20-2005, 03:22 PM   #3 (permalink)
sure could be the egr valve cycling closed and open..Its much quieter when it is open versus closed....my 2 cents..
j.schall
2005 f250 PSD 4x4,CC,LB Magnaflow 4" turbo back exhaust.
moovet is offline
Old 09-20-2005, 03:49 PM   #4 (permalink)
Unplugged my EGR for test puposes and this problem disappeared. You might have the dealer check it.
'04 F250 SC XLT 4X4 6.0 TS - Muffler Delete, Mobile 1
'73 F250 LWB XL 4X4 390-Far From Stock
'59 Plymouth Sport Fury 361 Golden Commando-Sweet
'85 Yamaha Vmax 160hp-Scarry
'80 Honda CBX 6cyl-Cool
hidesert is offline
Old 09-20-2005, 04:19 PM   #5 (permalink)
ZR1PETE's Avatar
Where is the EGR located? I'd like to try this test....
Thanks.
Pete
President and CEO Destructive Testing Systems
You Make It, We Break It, Guaranteed!
2005 F-350 King Ranch CC,DRW,
Manual 4X4 FX4 Dark Copper
6.0 Power Stroke and all the Options.
ZR1PETE is offline
Old 09-20-2005, 04:45 PM   #6 (permalink)
FamilyRide's Avatar
ON the '04's wiht the bad EB sensor that;s what it would sound like. Sometimes at idle, it would get quieter than a gasser, as in you could not hear the motor. It would last a few seconds then back to normal.
The EB controls the EGR and they replaced both on mine, last December. The latest recall replaces the EB wiht a new design and reprograms the ECM to operate the EGR differently. I don't know what is different on an '05 but that's exactly what a bad EB made mine sound like.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 09-20-2005, 04:48 PM   #7 (permalink)
Since he said orriginaly he had no performance issues i assumed it was the normal duty cycle of the egr but familyride is right the ebp sensor can contribute to this as well....
j.schall
moovet is offline
Old 09-20-2005, 06:57 PM   #8 (permalink)
My Photos: (5)
My 04 dually was doing the same thing , new ebp sensor , new egr , gone for now ....
55thunder is offline
Old 09-21-2005, 04:15 PM   #9 (permalink)
Forgive me if I'm way out of line here, but I noticed that your in FL.
Assuming it's pretty warm and humid, I wonder if your cooling fan is coming on occasionally? It makes a heck of a racket when it cycles on.
'06 F350 CC Red 4X4 Lariat auto
rickeg is offline
Old 09-21-2005, 09:30 PM   #10 (permalink)
Had the same problem on my February 05 production F250 and a new flash last month cured the same complaint. It helps reduce the EGR cycle time at idle. It also cured my engine surge (at constant throttle. Im my opinion, now the truck sound like a "real" diesel at idle (I'm coming out of a '97 7.3 and had no issue with that "noise" ... guess thats why there's a V10 gasser for the hearing sensitive). Now I'm keeping an eye on the mpg, as I have been averaging ~ 12 mpg before the flash. It's a hard swallow coming out of an "old" truck getting 19 mpg on a bad day. Try the flash, so far it's been pretty good!
Rob Healey is offline
Old 09-21-2005, 11:12 PM   #11 (permalink)
I have a 2004, 6.0 that did the same thing until I got a recall notice and I told the mechanic about this and he reprogrammed it with a new update. It fixed it!!
gearjammer65 is offline
Old 09-22-2005, 12:17 AM   #12 (permalink)
The new program "flash" reduces the egr duty cycle and the switching back and forth from quiet too loud, its the egr.....my 2 cents..
j.schall
moovet is offline
Old 09-22-2005, 02:40 AM   #13 (permalink)
Mine did this when brand new--never took it in and after the first outing it stopped doing it----maybe just the break-in blues---now seems to work fine---but I swear it acted as if the engine was no longer in the truck---totally stealth silent----almost wish I still had it!!!! lol--- [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Supercrew
2004 F250 Crewcab PSD FX4 Lariat--Oxford White--18" Stock wheels--Loaded--Grey leather--Bedliner--Chrome fender flares--3.73 rear end--6/21/04 build date--Custom Harley Flames just added!!
My other rides.....
2002 F150 XLT Supercrew, FX4 5.4l all stock
2001 F150 Lariat Supercrew 2wd 5,4l all stock
1995 Saturn SC1 SOHC 4 cyl.
1993 GMC Safari XT 4.3l 6 cyl.
1968 Chevy Camaro w/1989 Corvette 350 w 700r4 trans w/overdrive, Holley demon carb, mostly original.
2002 Wanderer Glidelite TT w/slideouts 26ft.
1974 Reinell Tri-hull openbow 165 horse OMC.
Cadillac Technician-A.S.E. Master and GM Master
Supercrew632 is offline
Old 09-22-2005, 10:50 AM   #14 (permalink)
FamilyRide's Avatar
...I swear it acted as if the engine was no longer in the truck---totally stealth silent...
It's kind of freaky huh? First time mine did it it was like it was an electric truck. I couldn't hear the motor so I stepped on the throttle to take off and after a second of 2 ot came back normal. But to not hear the engine at all, but still start to move, was a trip!
Old 09-22-2005, 01:28 PM   #15 (permalink)
ZR1PETE's Avatar
Hi BigRED06, To answer your question the truck goes in on Monday they told me the egr is cycling to much, I guess they have a fix for it.
Pete
ZR1PETE is offline
