?? Radiator Wet/Buildup ?? - Diesel Forum - TheDieselStop.com
Old 09-08-2009, 04:40 AM   #1 (permalink)
stonemasters's Avatar
Noticed on Passenger side of Radiator that about mid way there is a manufactor hole with buildup and slightly wet as well as along that whole outer core in that area there is buildup of what looks to be anti freeze along the edge. Looks to me like my Radiator is leaking and will need to be replaced. Any Thoughts??? Possible Causes??? Truck has 42,000 Miles and the Coolant System hasn't been flushed yet.
1996 Ford F350 4x4, Crew Cab, 8' Bed, 5spd, 7.3 Powerstroke with 141K Miles as of January 2012.
Current Mods:
Custom DP Tuner 60/80/120/EB
Magnaflow Downpipe Back 4" SS Exhaust w/5" Tip
Upgraded Stock 15Deg to 17Deg HPOP by Terminator Engineering.
Upgraded Viton O-Rings/Fuel Lines from Diesel Orings, Poly Body Mounts.
SKY Man. 3" RSK, Bilstein 5100's, Adjustable Panhard Rod, Pitman Arm.
35x12.50 BFG T/A KO's All Terrains on 16.5x9.75 Eagle Wheels.
Steel Braided Brake Lines, Ceramic Brakes.
Planned Mods:
Custom Paint, 3" Downpipe, Intercooler, Larger Injectors, Turbo, Custom Grille, NFab Cab Steps, Interior ReDo, Gauges, Bed Spray, Rebuild Trans, Stage 2 or 3 Clutch and More...
stonemasters is offline
Old 09-08-2009, 03:32 PM   #2 (permalink)
hazard05's Avatar
defect in the radiator... sometimes things just fail whether its due to poor materials used to make it or a craftsmanship defect.
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4 w/towing package, Chrome package, Billet grille, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod Edge Insight monitor w/EGT probe DeeZee bed mat, Stampede chrome bug shield. other than that its bone stock! Hopefully more to come!
"Run Hard, Dream Big"
hazard05 is offline
