Rear Diff fluid capacity? - Diesel Forum - TheDieselStop.com
Old 03-25-2009, 09:07 PM   #1 (permalink)
My owners manual does not give the fluid capacity? Does anyone know how much synthetic 75/140 it takes? I know I can pour it in until it overflows but would like to have enough on hand.
Thanks, Pat
06 F350 4x4 XLT, CC, LB, True Blue, 3.73LS, dash mount Pyro (ESOF knob), with stick, 40K miles, Toyo Open Country MT 275/70/18/E.
97 F350 4x4 XLT, CC, 136k.....SOLD to new owner
GOPDiesel is offline
Old 03-25-2009, 10:35 PM   #2 (permalink)
Rear Axle Fluid Capacity Specifications
10.50 inch Ring Gear 6.9 Pints ( 3.3 L ) *
Dana 80
Conventional and Truetrac 8.5 Pints ( 4.0 L ) *
Trac-Lok 8.0 Pints ( 3.8 L ) *
Dana S110 and S130 14 Pints ( 6.6 L ) *
* NOTE: Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or equivalent meeting Ford Specification EST-M2C118-A for complete refill of limited slip Ford axles. Ford design rear axles contain a synthetic lubricant that does not require changing unless the axle has been submerged in water.
2007 F250 6.0L Lariat
122,000 Miles
90% Highway Driving
Dieselsite Coolant Filter
PIAA Driving lights installed in Stock foglight spot
Edge Insight Monitor with Dash Pod
Pioneer Avic Z2 Nav w/ Sirius Satellite Radio
CB Radio w/ Firestik Antenna w/ Hood Mount
06 Harley V-Rod Street Rod Yellow
Rccarps2 is offline
Old 03-27-2009, 10:47 PM   #3 (permalink)
expertrider's Avatar
You also have to change it if it's leaking. Mine was doing this.
Anyone changing the rear diff oil should buy the 08 cover. It's much better and keeps the oil cooler.
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 W/eXtreme tunes from Innovative,
but staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky sneaky!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
expertrider is offline
Old 03-28-2009, 11:19 AM   #4 (permalink)
Thanks for the responses. Too bad sythetic diff oil is so expensive!
