I'm planning on changing my rear diff. fluid and want to know what type of gasket it uses. Is it reusable? Do you use permatex on it? Thanks [img]/ubbthreads/images/graemlins/cool.gif[/img]
~2004 F-250 Quad cab long bed, 6.0L PSD,4x4 ~Torqshift Trans
~Arizona beige,tan interior
~Running boards w/custom Piranha LED lights
~ARE bedcap, Bedrug
~Foglight/high beam mod,BriteBox,HD light harness
~Zoodad mod, High idle mod
~Coolant filter, Oilguard bypass filter, Fumoto
~Isspro pyro,trans temp,boost in A-pillar
~Marinco Block Heater Receptacle
~Bodiak front hitch
~Mag-Hytec rear diff cover w/6qts syn fluid
~250 watt oilpan heater
~Scanguage
There's no gasket. Use high temp silicone. Be sure both mating surfaces are clean and the bead goes to the inside of the bolt holes. Install the cover within 15 minutes of applying the silicone and torque the bolts in a criss-cross pattern. Wait at least an one hour before filling diff.
Do you have that many miles on it, or has it been "dunked" somewhere?
__________________ 2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
Only have 8000 miles on her but I'm taking my 2 boys on a cross country camping trip this summer(Philly to Montana) and thought I'd give the rear a fresh bath for piece of mind. [img]/ubbthreads/images/graemlins/cool.gif[/img]
~ARE bedcap, Bedrug
~Bodiak front hitch
~Scanguage
