rear main seal leaking - Diesel Forum - TheDieselStop.com
Old 04-04-2009, 09:21 PM   #1 (permalink)
Exclamation rear main seal leaking
all, need some tech advice, i have a 2006 F350 crew cab, last December, I had a leak between the engine and tranny , the dealer replaced a gasket and said fixed....ok well Feb, 09 another leak in the same place and they replaced the seal again, this time they added dye and to verify that it was leaking....i thought pretty smart......and of course yes it leaked agin this time worse.....so now they tell me they need to pull the engine and replace the crankshaft and a sleeve....they couldnt explain where the sleeve went and what its purpose is........so i m totally confused....
sspo is offline
Old 04-04-2009, 09:37 PM   #2 (permalink)
Banned
How much oil are you losing?
trailerlugging is offline
Old 04-05-2009, 04:53 PM   #3 (permalink)
the spot under the truck is 4 to 5in diameter.....
sspo is offline
Old 04-05-2009, 06:00 PM   #4 (permalink)
pjwoolw's Avatar
My Photos: (5)
Probably it's the bed plate seal that is leaking. All to common. Mine leaks too but not that badly yet. Still have 11 months to get it fixed.
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
