Old 11-01-2009, 06:56 PM   #1 (permalink)
thephoneguy's Avatar
Question Red cable from alternator to battery 1...
I have a 2006 F-250 Diesel truck. Hy hypercgarger touch screen displays a nominal voltage of 12.6volts. I am suspicious that the red cable from my alternator to battery 1 may be defective and i am willing to replace it with a thicker gauge one. The problem arises that the factory one goes down like into the engine covered with a heat protector cover and am not sure where it goes. As a test I disconnected it and installed my own 2 Gauge cable from the alternator to battery one. Now nominal voltage came up to 14.6 but I am not sure if I am overriding any regulator, filter or whatever the factory cable one goes thru in this hidden route i can't follow or see. Am i doing something wrong? Should i leave the new cable gauge 2 as is or what? Can someone help?
thephoneguy is offline
Old 11-01-2009, 07:04 PM   #2 (permalink)
Leave the new cable on or fix the old one. The connector at the alt. is a common problem. The regulator is built into the alt. so you are not bypassing anything. repair the old one and leave the new one and you have double protection and could upgrade to a beefier alt. if needed.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-01-2009, 07:34 PM   #3 (permalink)
Thank you, i appreciate it very much.
Old 11-03-2009, 12:14 AM   #4 (permalink)
Smile Another problem arised...
I left the factory red alt cable on and added a new gauge 2 cable to it. If I disconnect the factory cable it reads 14.6 volts however if not and leave it connected it reads 12.6 volts. Are you sure this factory red alternator cable doesn't stop anywhere between the alternator and the 1st battery?
Old 11-03-2009, 01:32 AM   #5 (permalink)
KevinTamu's Avatar
Phone Guy, I'm pretty sure the stock goes directly from the alternator to the battery one. I could be mistaken though. Also, are you doing this when the glow plugs are still cycling? If you are, the voltage will read 12v-12.5v or so until they stop cycling, then it will spike to around 14v. This could be your problem.
2006 F-350 King Ranch 4X4 - 63K miles
- Jl 13w7 powered by 1000/1v2 --- 2 Yellow Tops
- Jl 8w7 powered by 250/1 --- 220 Amp HD Alternator
- JBL performance components powered by Jl Amp
- All ran by Pioneer head unit
- 30 Farad Stinger Capacitor
- 4.5 Don. Rac. Lift Kit
- 35X13.5 Dick Cepek
- 18 inch Mazzi chrome rims
- Excalibur remote start alarm
- 5 inch custom exhaust
- Many more cosmetic mods and SCT custom tune.
KevinTamu is offline
