Ok, no where on the tach or in my owners manual is a max rpm or even a caution range indicated or specified. Ford website specifies torque at 3300rpm, is that red line. Would like to know, actually I think I NEED to know. Oh by the way, just took delivery of 06 F350, DRW, 4x4, CC, LB, King Ranch, PSD, 3.73, dark copper. SWEEEEET!
Thanks for your help.
2006 F-350, PSD, DRW, 4x4, King Ranch CC, dark copper, moonroof.
Wolf
Kentucky built 2004 Silver F-250 XL Reg Cab PSD, 4X2, bench cloth seat,air conditioning, 6 spd Manual, 3.73 LS,Line-X , FORD receiver, Prodigy brake controller,towing option,( put together on Monday, March 29, del April 9 2004) 62000 miles
You have an automatic. Stock it won't come close to redline, and it's not even making power near red line. [img]/ubbthreads/images/graemlins/laugh.gif[/img] Tuned is a different story.
__________________ 2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
I am unsure if there is a published "redline" rpm... the PCM will keep you from over-revving when accelerating - "over-speeding" the motor going downhill is another story... I would be going much past 4000 rpm - if I let it get that high.
FWIW... in stock trim, torque peak is about 2000 rpm and remains relatively flat up to horsepower peak around 3300 rpm. After that, torque starts to fall off. Translation... for best results, upshifts should be made to enter the next higher gear at the rpm where you motor is making the best torque.
While keeping the rpm up is important, it serves no purpose to rev until it wont rev no more...
I wouldn't worry about overspeeding the motor going downhill. Have you guys ever heard of a "runaway"? The fastest I've seen one turn and survive is about 8,000 rpm..
in the manual ( diesel motor ) that is given to new owners, there is a section on gear selection vs road speed and at the end it does caution against overrevving the motor by shifting too low on downhills or while going quite fast. I can get the numpbers and post them here on edit later in the day. I don't believe the automatic guys can do that as it is impossible to push start the PSD.(power won't flow back to the engine thru the auto )
There is a redline on my tachometer that starts at about 4100,
Wolf
There is a rev limiter on the 6.0(Governor if you will) According to International you cant go over the "red line" because of the Governor. The computer ain' gonna let it happen. Therefor no need for a "red line". This is for the 05 and up. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2005 F250 6.0 PSD CC Auto, Dk toreador red/Ariz beige,Lariat Luxury 4x4 SB,TT Mirrors,Camper PKG,Roof lights,ADJ pedals,REV aid,Trailer hitch,TOW COMMAND,ESOF,PWR rear window,3.73 posi,SIRIUS SAT radio. Built 08/09/04 2005 F250SIRUS RADIO
2002 BUYBACK bad paint F250 7.3 PSD Auto CC Lariat 4x4 SB, TT mirrors,Camper pkg,Grille insert,Hood shield,Tow pkg,Adj pedals,Shift on fly,Trailer brake,Spray in bedliner,Dk highland green w/tan. 2002 F250
Unless you have a manual transmission going down a mountain in a low gear the RPMs will go over the governed RPM.
2008 F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
The owner's manual for the 6.0 is (or was when I got my '05) identical to that of my '02 7.3 as far as upshifts and downshifts on a manual tranny. Those of us who have owned both know that to be BS. That's why it took me awhile to get used to driving the new truck- I was afraid to rev it high. The 7.3 didn't seem to like that. I have wondered if the stock tach is accurate- my truck has "tached out" anywhere from 3500 to 4100. I also found it peculiar that the tach had no redline indicated on it. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
It does have a redline around the circumference starting at about 4100 RPM indicated.
Wolf
Okay, here's the deal. While I am NOT concerned about reaching or hitting "red line", I would like to know so that I can compute percent of max. I spent 3 hrs driving this sweeeet beauty today, there is NO fricken red line on the tach! Nothing in the manual. I don't NEED to know, I WANT to know. I have made my living since 1976 flying airplanes, and currently am a Captain for a major airline, so I just get into this kinda stuff. Hey, who cares how much oil the crankcase is supposed to hold unless you just "need to know" or want to know.for whatever the underlying reason. Anyhow, just like to know. Just like I'd also like to know what the yellow line temp on the trans represents in degrees, hell, it doesn't matter celius or farenheit, give me a number.
Thanks.
Regards to all.
I've asked this question also. I was told 4100. The reason I wanted to know is that with my tuner the truck never falls off on power. Pulls hard all the way to 4000. My 03 does have a redline on the tach at about 4200, but my manual says don't rev over 3600 and the governer will kick in at 4000.
I think I'll keep shifting mine around 2500-2800. This seems the best. But I'm pretty confident that in saying 4100 is safe redline.
03 F350 Crew cab, XLT, long box, 4x4, 6spd, single rear wheel, 4" straight pipe, SCT Xtreme, ARP head studs.
