Reflash for tranny shudder - Diesel Forum - TheDieselStop.com
Old 02-28-2005, 09:22 PM   #1 (permalink)
Took my 05 F250 in for a transmission shudder, only shudders if under heavy load (pulling trailer) or if stomping it from a stop. Only does it in first gear, as soon as it shifts, its gone. It's not wheel/axle hop. They said that the 05B27 recall fix will fix that, but then they reflashed the ECM and said this new program will fix tranny shudder that I described.
It didn't do diddily. Shudder still there. Anybody ever hear of a flash that fixes tranny shudder on the 05's? How is a new snap ring in the 05B27 recall going to fix tranny shudder. I think maybe he has that one mixed up with the 04B24 recall. Anybody have an idea what causes this tranny shudder?
Red '05 F-250 PSD Lariat 4x4 FX4 SB Crew Cab
GrizzFlyer is offline
Old 03-03-2005, 11:29 PM   #2 (permalink)
Re: Reflash for tranny shudder
I have a shudder if I hit resume on cruise control to get back up to speed. Not sure if this is the same thing, but I think it is the torque converter doing something strange. I'll be taking it in soon to see what the dealer thinks.
2003 F-250 7.3L Lariat CC 4X4
Torreador Red
"old" truck photos, new ones coming soon
Truck Pics
catadjuster is offline
Old 03-04-2005, 03:15 AM   #3 (permalink)
That is the first I have heard that it is the trans. There is TSBs talking about shudder under acceleration and they say it is the angle of the drive shaft. There is a TSB for 2 piece drive shafts and another for 1 piece drive shafts.
2004 F250 6.0 PSD, XL Reg. cab, Torque Shift, 3.73 limited slip. Build date 9/03.
2004 26ft Salem fifth wheel w/super slide 6500#.
Krispy is offline
Old 03-04-2005, 08:59 AM   #4 (permalink)
Thanks for the info Krispy, I'll check it out further
Torreador Red
Truck Pics
Old 03-07-2005, 02:39 AM   #5 (permalink)
I think it is the trans too.
They tried twice to shim mine to fix it with no luck. Ford Engineering says there is no fix if the shims don't work and that the shudder is "normal". Feels to me like the clutch packs in the trans are chattering on lockup and load.
So if the TSB shim fix does not help you, you're SOL according to Ford.
'03, F-350 Lariet, CC, DRW, 5sp torquemaster, 4X4, 4.10ls, Sonic Blue monotone. Hijacker 16K full pivot/slider 5th wh hitch. One PRETTY truck [img]/ubbthreads/images/graemlins/wink.gif[/img] UPDATE: Truck is still performing poorly, though it is better since the last reflash that removed the EBP sensor inputs. Has definately been the worst truck I've owned in my 30 years driving Fords.
BigOne is offline
Old 03-07-2005, 10:57 PM   #6 (permalink)
What is a tranny shudder? I am having an issue also with towing my horses. So what is a sudder? Annie
2005 F250 SB/CC King Ranch oxford white 4x4, Moonroof, Line-X, Retrax, aftermarket window tints, uplifter switches
annieacres is offline
Old 03-08-2005, 06:38 AM   #7 (permalink)
Hello, When I kick off the cruise and then hit resume I get a shudder. I have been unable to duplicate this manually. Also if I shift to reverse and give it throttle quickly it will shudder. My truck was built around 11/1/2004. Is the TSB supposed to address this problem?
2005 F-350, Crew Cab, Cab Chassis, 9 ft flat bed, 6.0, Auto, 3:73, 4 Wheel Drive, XLT, GVW with full fuel 9600#.
sbpowelljr is offline
Old 03-08-2005, 03:50 PM   #8 (permalink)
I had a shudder on my 04 when I would pull my 5th wheel. I took it in and they shimmed the driveshaft. That did nothing for the shudder.
I found that when I hitched up my trailer, the back of my truck dropped 2-3". I install a set of air bags in the rear and now keep the truck at the same height hitched as when it is unhitched. It has eliminated the shudder. Works for me.
Wayne
2004 F350 6.0L,AT,Lariat Pkg,CC,DRW,FX4,4.10 LS,Moonroof,Power rear slider,dual alts,AIC,HD Susp.15k hitch and heated leather captains front chairs. Build date 1/25/04
PSDFF is offline
Old 03-09-2005, 12:50 AM   #9 (permalink)
Wayne_J:
Interesting. So it could well be the ride height change that causes the shudder to be more pronounced when towing.
Sorry you had to spend your own $$$ to put in airbags when the issue should really be fixed under warranty. But we all know Ford does not honour their warranty, just claims it a "normal characteristic of the trucks".
BigOne is offline
Old 03-09-2005, 04:44 AM   #10 (permalink)
I had a 02 7.5 rhat had the shdder and it turned out it had a cracked piston in the forward gear that went completely out at 41,000 It had the shudder from day one new and it is exactily like you guys describe
04 6.0 F-250 Lariat CC FX4 Build Date Trk 06\04 Motor 04\16\04 Black 3.73's Torque Shift, Tonneua Cover,Bug Shield,Window Louvers, Fender Well Chrome, Rocker Panel Stainless,Fumote Oil Valve,Flint Leater Heated Seats, Heated Mirrors,Six Cd Stereo,Over Head Console
Simp_04_Diesel is offline
Old 03-09-2005, 11:09 AM   #11 (permalink)
Mine shuddered real bad at one point. Center carrier shims helped somewhat... Finally noticed the driveline was apx. 5/8" out of line horizontally from front to back. Moved the center carrier to the left as far as it would go to line it. It is still out maybe 3/16" or so, but currently there is no shudder under any circumstance and I am not going to press my luck and mess with it more.
Chris
On edit: here is a link to the thread:http://forums.thedieselstop.com/ubbt...v=#Post2222221
mcn6 is offline
Old 03-09-2005, 03:02 PM   #12 (permalink)
Interesting, so that would be why it feels like internal transmission engagements, if one has a cracked piston in there.
Sounds like checking the side to side alignment is a good idea too. I'll have to look at that.
BigOne is offline
