reman turbo antiseize? - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 09-25-2008, 03:08 PM Thread Starter
I just got a reman turbo from the stealership part#1877833c91.
Should I antiseize the ring before I install the turbo?
What did they do to fix the problem on these turbos?
Thank you,
Rob
2001 F-250 4x4 superduty
taxidermist48836 is offline
post #2 of 11 (permalink) Old 09-25-2008, 06:07 PM
OT
OT's Avatar
Read what FDR. says about assembly. Reliability is anyone's guess?FDDTS - Turbocharger Reconditioning
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #3 of 11 (permalink) Old 09-25-2008, 07:22 PM
i would leave it alone. the new turbos are machined a little different to keep rust from building up. i havent seen replacement turbos go bad unless something else is going wrong with the truck.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
post #4 of 11 (permalink) Old 09-25-2008, 07:58 PM
OT
OT's Avatar
taxi..is this t. for a 6L?
fboy...curious, how would being machined alittle different keep rust from building up? TIA
OT is offline
post #5 of 11 (permalink) Old 09-26-2008, 05:08 AM Thread Starter
Yes 03 6.0 with 65,000 miles
post #6 of 11 (permalink) Old 09-26-2008, 05:13 AM Thread Starter
I tried to do this first and it was so pitted up under the ring and the ring had to be pried off the housing so I got a reman turbo but they say they fixed the problem with them???? we will see.
Rob
post #7 of 11 (permalink) Old 09-26-2008, 05:33 AM
ford_doctor's Avatar
I have seen the new style CRH bind but it is very rare. The use of anti-seize is not meant to provide lubrication but rather to protect the metal from rusting and it should be applied in a very thin coating. Ford remans come doused with clean engine oil and the turbocharger reconditioning TSB has us use oil. I don't see any point to the oil if the turbo is being serviced by a technician to be immediately reinstalled on an engine but if it is sitting on a shelf somewhere it prevents rusting. The Navistar TSB has us use anti seize. Which is better? In the long run I would say neither but high temperature anti-seize will last longer and oil will burn off immediately.
To the original poster, I would just install the turbo and be sure you have the updated oil drain tube.
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #8 of 11 (permalink) Old 09-26-2008, 02:32 PM Thread Starter
To the original poster, I would just install the turbo and be sure you have the updated oil drain tube.[/quote]
Well its off to the dealership again to order parts. You would think if it is a updated part they would send it with the turbo........ Why did they update the drain?? and man is that a muther funckner to get in.
Rob
post #9 of 11 (permalink) Old 09-26-2008, 06:22 PM
OT
OT's Avatar
taxi...replies got me curious..change's made VGT 03/06 6L TURBO My t. replaced under warr. 11/06 # 3C3Z 6K682 BARM. Tube # 6C3Z 9T515 A which maybe one FDR. mentioned? I think tube diameter was increased, but don't recall for sure. Point is...
I got reman. t.....you just got a reman., but sounds like it will be a redesigned one. Makes me wonder if mine was a redesign.? Anyhow..Good luck!
OT is offline
post #10 of 11 (permalink) Old 09-27-2008, 05:16 AM Thread Starter
I think that is what they are changing on the newer 6.0 as far as what they did to my reman turbo???? who knows maybe more clearance between the housing and the ring I hope?? and as far as the updated oil drain the hole in thr intake and turbo is still the same size I will see Monday when the part gets here.
Rob
post #11 of 11 (permalink) Old 09-27-2008, 11:28 PM
Banned
Rob[/quote]
The updated drain pipe has a larger ID.... Ford tells us this will reduce coking and, from what I can see, it appears to help.... To install the drain, simply make sure everything is clean that needs to be clean, oil the O-rings and install the tube... If it's fighting back, something is wrong.
GrampyJim is offline
