Remove transmission first?? - Diesel Forum - TheDieselStop.com
Old 10-21-2008, 08:54 PM   #1 (permalink)
Im just getting ready to change my engine for a new one, and the third step on the ford service manual reads
"On vehicles equipped with manual transmissions, the transmission must be removed before the engine can be removed"
Does anyone know why? Is this a true fact that must be done, or is it one of those "must pull the cab to pull motor" deals? can you get around it?
Thanks!
rckstr is offline
Old 10-21-2008, 09:14 PM   #2 (permalink)
no it does not have to be removed they say this just to make the job easier wich it would if you remove the front rad support nuts and front cab mount bolts you can lift the front of the cab enough and place a 4x4 or 6x6 in front of the rad support gap to ease in clearing the input shaft we do this all the time at our shop and no issues
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
Old 10-21-2008, 09:20 PM   #3 (permalink)
alexb's Avatar
I do the same thing with engine removal (lift the front of the cab slightly). The reason they tell you to remove the transmission for manual trans. is because it is very difficult to line up the input shaft when reinstalling the engine. I just roll it back slightly to get it out of the way, but don't completely remove it.
alexb is offline
Old 04-02-2009, 11:30 PM   #4 (permalink)
do you know how many bolts there are on a 1997 F-350 7.3 diesel manual transmission?
laceyshw is offline
