Originally Posted by brandonoliver01
ok i will get the scan gauge 2 that will read ipr and go from there i can not see it on my truck i need to check it to see if im getting atleast 500psig to fire the injectors correct? what would shavings in it mean?
brandonolivero1
This post is stogie's post. It should be related to his problem. If you are having a problem with your truck you should start a new thread.
The scan gauge II is a good tool to help diagnose problems with your truck. Personaly, I purchased the Auto Enginuity software for my laptop. It will do more to narrow down the problems associated with the 6.0. Very helpful in finding injector problems. Kept me out of the dealership.
Shavings or small metal particles in the screen in your IPR valve would be a good indication of your high pressure pump failing. I have heard of screens that have been torn or collapsed that can be fixed by simply replacing the screen.
Again, if you are having a problem with your truck, you will get more advise starting your own post. or you can send me a private message (PM)
