Old 06-30-2009, 08:10 PM   #1 (permalink)
EBX
EBX's Avatar
My Photos: (6)
Replaced Turbo w/ Reman. Factory Turbo - Now 5 lbs. less Boost????????
The last Ford dlr. replaced my turbo at 63K w/ a remanufactured Ford turbo b/c they said my turbo was shot.
Out of warranty of course.
B/f the turbo change I would get 24 lbs. of boost at WOT since I bought the truck new.
Now, the max boost I can get at WOT is 19.5 lbs.
What gives? Did Ford tune down the turbos?
The X is 100% stock.
'03 Eddie Bauer, Excursion 6.0 PSD (Bought New) & (All Stock), 4WD, 3:73 Limited Slip. 6.0 build date March '03, Premier group, video pkg, roof-rack (lighted), 3 pillar pod, Timbrens-on back.
I change oil every 5k (Rotella Syn. 5W-40), fuel filters every 10k (Ford Filters Only), air filter every 30K (Ford Filter Only), Changed trans. oil/filter & diffs. oils at 50K. Mostly highway miles & some around town.
From 5/23/09 - 6/19/09 At 62K miles & 9 months out of warranty, I spent $8K b/c of & getting this X fixed; 3 Ford Dealers in 3 dif. states replaced: EGR Valve, Cleaned Turbo Pipes, IAT,Map Sensor, ICP, VGT, (Cleaned Turbo -Compression ring still sticking), Replaced Turbo. On 6/19/09 I bought Ford Ext. War. 4yrs./48k.
Buy your Ford Factory Ext. Warranty.
Check link for pics. & info.
http://community.webshots.com/user/ebx03
EBX is offline
Old 07-02-2009, 11:56 AM   #2 (permalink)
EBX
EBX's Avatar
My Photos: (6)
Bump.
EBX is offline
Old 07-02-2009, 05:29 PM   #3 (permalink)
dikkstarr's Avatar
24 is too low for an 03. Back in 04, mine would hold 32lbs. Maybe your gauge is worn out..
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , white with 12" lift, flip steering, 38s on 17 10s, stock gears, superlift truspeed, fumoto, floating traction bars, airraid intake with elbow,4" turbo back, studded, powerslots, 55 watt HIDs 6000k heads and fogs,clear corners,7" NAV w/ back up camera, massive stereo, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,,coolant filter kit,hush panels and door seal mod,
dikkstarr is offline
Old 07-02-2009, 05:53 PM   #4 (permalink)
ANY time that an 03 has anything changed in the air system (EGR, VGT MAF etc) it must have the KAM (Keep Alivce Memory) cleared and must be allowed to go through a VGT relearn procedure. IF not done, it will not function correctly untill it has remapped itself, which can take a LONG time. Get it warm, unhook the batteries for 10 minutes, rehook, start and let it idle in park with the AC off for 5-10 minutes. IT should relearn. You should be able to hear a noticeable change in exhaust tone as it steps through the relearn procedure. IT will go through the steps several times.
BEfore you do, be sure that there are no exhaust leaks or fresh air leaks and that the MAF is clean. Otherwise it will never learn its maps.
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is offline
Old 07-03-2009, 10:58 AM   #5 (permalink)
EBX
EBX's Avatar
My Photos: (6)
It's worth a try. Thanks.
EBX is offline
