Replacing A/C compressor - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 07-23-2011, 06:55 PM Thread Starter
I need to replace the compressor on my 04 f250, anyone have a link to a walk through to make it a little easier, I did a search but couldn't come up with much besides the fact that it is a pain in the butt to do.
Mdotson is offline
post #2 of 7 (permalink) Old 07-23-2011, 07:10 PM
chuckster57's Avatar
Unless you have all the right equipment and gauges, I wouldn't bother doing it yourself. The proper way to do it is to recover all the refrigerant, and then remove the compressor. Flush the system to remove any contaminants or metal from the compressor failing. Replace the drier/reciever and orifice tube, Then Evacuate the sytem ( pull a vacum) to remove any moisture. Then Charge with nitrogen to test for leaks and if none then remove nitrogen and charge with R134a...
You will need a good vacum pump and a set of manifold gauges at least. I suppose if all the refrigerant was "gone" when you started taking the lines off the compressor, then you wouldn't have to recover the stuff. FLUSH is very important if the internals of the compressor failed as it will spread metal shavings everywhere. Drier/reciever change is normaly a requirement for compressor warranty.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 7 (permalink) Old 07-24-2011, 02:02 AM
In addition to what was posted already you will find the bolts may not come out far enough without loosening RH engine mount from frame and jacking engine up a bit. Direct mount components reduce noise-vibration-harness but they increase PITA a fair amount.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a, SCT, 4in exhaust. 103K New heads to repair diesel in coolant.
2006 F350 Lariat CC Dually 4X2, 6.0 TorqShift 4.10 LS, SCT, airbags, 4 in. exhaust. 147K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
2003 EB Expedition 149K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 228K (no engine repairs)
2007 BMW 550i 6MT 130K
jimmy is offline
post #4 of 7 (permalink) Old 07-24-2011, 01:09 PM Thread Starter
Hmm well I might just say forget it and deal with it next spring, summer is almost over and I can deal with the heat for a little while lol. Thanks for the info guys.
Mdotson is offline
post #5 of 7 (permalink) Old 07-24-2011, 03:21 PM
If your compressor failed internally you should replaced the condensor, as it cannot be flush very well.
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
post #6 of 7 (permalink) Old 07-24-2011, 03:57 PM
If your gonna wait, then I would take the connection off the clutch. That way this winter when you put the defrost on, it doesn't engage the compressor.
Train Horns:
post #7 of 7 (permalink) Old 07-25-2011, 12:06 AM Thread Starter
Ok thanks a ton for the info.
Mdotson is offline
