Rocker arm failure - Diesel Forum - TheDieselStop.com
Old 03-08-2009, 04:40 PM   #1 (permalink)
Rocker arm failure
o4 F-550, 6.0L Motor was making popping sound so I pulled valve covers. I found 1 broken rocker arm. It looks like it just broke in half. The fac. manual says to remove cyl head because head bolt has to come out to replace rocker arm, it also says the inward head bolts can't be installed with the head on the engine because the head bolts hit the body of the truck. Does that mean that I have to pull the engine to replace a rocker arm
EVtech is offline
Old 03-08-2009, 05:20 PM   #2 (permalink)
I have read of guy's pulling the heads with the cab on. When I had headstuds put in they pulled my motor out of the truck, the tech said that it was easier then lifting the cab.
BP6.0 is offline
Old 03-08-2009, 05:41 PM   #3 (permalink)
ZMANN's Avatar
what a pain! what did your stud job cost this rocker arm job seems like a good excuse for the studs
ZMANN is offline
Old 03-08-2009, 06:19 PM   #4 (permalink)
ford came out with a tool to do it, you have to take that injector out and a peice bolts in the hole with the injector hold down and pushes the valves down so you can take the rocker off the bracket.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 03-08-2009, 08:22 PM   #5 (permalink)
OT
OT's Avatar
EV..if body/e.bay same as F250..dont have to pull e. Look at "My Photos" Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 03-09-2009, 07:15 PM   #6 (permalink)
Thumbs up Rocker arm
Thanks for the answers. The special tool sounds like the way to go. I don't know where to get one but maybe I can make one.
EVtech is offline
