rough idle and blue smoke on cold start up? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 11-15-2011, 05:21 AM Thread Starter
truck will idle rough and i get a puff of light blue diesel smelling smoke on cold start up under 60degrees outside.Rough idle will last for about 20sec same with blue smoke and then clear up.I live in Nh and i run rotella 15w40 all year.Any help would be great.Oh yeah 2005 f-350 with 30k on new ford reman which came with new injectors,oil cooler,egr cooler also.
2005 F-350 6.0 XLT crew cab FX4 4x4
51k on New motor,123k on truck
scangauge II as guages
Blue spring upgrade
4" turbo back MBRP
Zerex CAT EC-1 coolant
K&N cold air intake
Build date of 01/2005
2008 30' zinger TT
neal8809 is offline
post #2 of 12 (permalink) Old 11-15-2011, 12:09 PM
bought my 2005 just back in June, so I'm only on my second oil change and just recently experiencing cooler weather with a diesel for the first time. My original oil change I used Rotella T 15w40 and when the weather started cooling off, I had a couple of days where I had the symptoms you're describing. I changed to Rotella T6 5w40 a few weeks ago and it seems to have fixed it.
I guess it would also be good to know what your FICM voltages are just to be thorough.
Idahoser is offline
post #3 of 12 (permalink) Old 11-15-2011, 12:26 PM
Feedback Score: 2 reviews
Sound like stiction need to use a top grade 5w40 Syn oil use Ford filters only only 5000 miles on oil changes run cetane boost in the fuel i use the Ford stuff helps keep the egr valve and turbo clean. You might try this in the oil they say it works wonders REV-X Oil Additive | Diesel Fuel Additive | High Performance Oil
http://www.alliantpower.com/pdf/APTB-0109-watermark.pdf
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #4 of 12 (permalink) Old 11-15-2011, 05:02 PM
SmokerSteve's Avatar
Also test your ficm.
FICM Testing Videos
With only 30,000miles on the injectors I am doubting that it is stiction, could be stiction, but I doubt it.
2006 F-350 79,000
FICM Testing Videos
How to get more than 8-7 Quarts Transmission FLush
Stock Truck, DTC, California, and SMOG safe EGR System Mod
SmokerSteve is offline
post #5 of 12 (permalink) Old 11-15-2011, 08:06 PM Thread Starter
so you guys recommend 5w40 in the winter and switch back to 15w40 in the summer and is there any other brand other than rotella that you recommend?
Blue spring upgrade
4" turbo back MBRP
K&N cold air intake
2008 30' zinger TT
neal8809 is offline
post #6 of 12 (permalink) Old 11-15-2011, 08:21 PM
dieselmac's Avatar
5w year around. It's now Ford approved. Your injectors will thank you.
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #7 of 12 (permalink) Old 11-15-2011, 08:25 PM
No need for switching between 5w-40 and 15w-40. Stick with 5w-40 unless you want the cheaper price of 15w-40.
dello
mobil
chevron
rotella
cant think of any others off the top of my head that are sold at common local stores, but they are all good.
2006 F-350 79,000
FICM Testing Videos
post #8 of 12 (permalink) Old 11-15-2011, 08:59 PM
dello
mobil
chevron
rotella
Mystic
Royal Purple
Amsoil
Eric
2004 Ford Excursion Limited
4X4, 6.0, 1/2004 Build date
Solid Black, Secret Service Look alike
Stock engine w/ EGR Delete
4" turbo back exhaust w/ Deleted Cat
2004 Ford F-250 King Ranch
4x4, 6.0, 2/04 Build Date
Chestnut Brown Metallic
Stock engine with EGR Deleted
SCT Livewire TS from Innovative Diesel
2003 Ford Excursion Limited (Totaled 5/1/2015)
4X4, 6.0, 2/2003 Build date
Bone stock at this point
Very few issues over its life...
knightgang is offline
post #9 of 12 (permalink) Old 11-15-2011, 09:22 PM
STG
I've been running 5w-40 (Rotella T6, Mobil 1 for Turbo Diesel Trucks and Delvac 1) in my 2005 since 2005.
There is no reason whatsoever to change to 15w-40 during summer. Your batteries, starter, FICM and injectors will all last longer when your engine pumps 5w oil on cold starts. That's cold starts in winter as well as summer.
I've read countless threads about guys plugging in block heaters at +45F. Really? Try 5w-40 instead. I've cold soaked my truck at -25F for 8-10 hours several times here in Northwest Wyoming without plugging in the block heater and have experience no starting issues.
Twice after a -25F 10 hour cold soak I started my truck at the same time another 6.0 was starting his. Both times the other truck cranked for a while and wheezed to life bucking and jumping around. It was painful to watch and hear. Once, the driver came up to me and asked how I got my truck to start so quickly and run smoothly. I asked what oil he was using. 15W-40 conventional.
Using 5w-40 is the easiest cheapest thing you can do to enhance the reliability of your truck. The second is keeping your batteries hooked to a Deltran Battery Tender.
Stan
2005 F250 4X4 SD R/C Power Stroke / Torqshift
Oxford White, Medium Flint 40/20/40 Vinyl, Prefered Equip. Pkg. 600A , 3.73, Limited Slip, XL Decor Pkg., Jeweled Headlamps, Chrome Rear Step Bumper, 9600# GVWR Pkg., Engine Block Heater, Sliding Rear Window, Speed Control / Tilt Wheel, Camper Pkg., FX4 Pkg., Air Conditioning, Forged Aluminum Wheels-17", Tow Command, Telescoping TT Mirrors. Using this vehicle to produce an ambulance voids Ford warranty. Added: Ford factory upfitter switches, Go Industries Rancher Grill Guard (hammered powdercoat), Hella 4000 Rallye lighting (two Euro Beams), SnugTop Super Sport camper shell, Jotto Desk & Escort Redline Radar/Lidar Detector.
STG is offline
post #10 of 12 (permalink) Old 11-16-2011, 06:28 PM
I am having cold start issues as well. Here is my story......
Back in early 2010 I started having these cold start/rough running issues. I put up with it for quite some time and when winter came along I had to do something so I researched here and found out about the heat indtuction flash. I had that done in December 2010 and it cured my cold running issues, plus now the VGT cycles while idling to prevent the vanes from sticking.
Late this summer it started doing it again and for the last three tanks of fuel it has been even intermittently missing under load with the engine warm. Sometimes it will do it sometimes it wont when warm but ALWAYS when it has sat and cooled down.
So I start rersearching here again and decide I better test my batteries and my FICM.
Here are my results from last night......
Batteries Key off - 12.5 v
FICM Key on engine off - 48.5 v
FICM engine running - 48.4 v
So, where do I go from here? I am running Mobil Delvac 15W-40, and just changed it 3 weeks ago. Should I dump it and go with 5W-40 Synthetic? I also changed fuel filters last Friday. Should I take it to the dealer to see what they can find with a scan?
Any help would be greatly appreciated.
2012 F-350 Lariat Crew Cab long box
2016 Ford Escape
2013 Work & Play 25UL Toyhauler
2014 Polaris RZR XP 1000
2002 Polaris Scrambler 500 H.O.
prayingforluck is offline
post #11 of 12 (permalink) Old 11-16-2011, 06:53 PM
I have been running Mobil Delvac 15W-40 in my 97 way back when it was a 1200 series now it is a 1300 series but the old 7.3 is not a 6.0 if your ficm checks out i would switch as in my post above and try the Rev-X they say it works. I run a 15w40 in my 7.3 and 5w40 in my 6.0 and they both run great when it is cold the 6.0 injectors do not like a heavy oil because these motors move a lot of oil at startup and while running.
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
post #12 of 12 (permalink) Old 11-17-2011, 07:06 AM
Bully Joe's Avatar
2 stroker
Good info, thanks.
Bully Joe is offline
