rough idle at cold starts - Page 2 - Diesel Forum - TheDieselStop.com
Old 10-29-2008, 05:49 PM   #16 (permalink)
RAVOwner's Avatar
Talked to one of the mechanics where I work and found out that we recently had a 6.0L service truck go to the dealership with the same problems I am having with mine (see my post above). He said the truck got so bad that it was no longer driveable, which is how mine is getting. Anyways he said that all the dealership did was reflash the computer with the inductive heat program and did something to the HPOP. I asked if was the STC fitting and he said he wasn't sure. But there was no injector work or replacement. He said since the truck has been back it has run great without any problems.
05 F350 SRW CC LB FX4 Lariat
6 Inch Procomp Lift / Superlift Stainless Steel Brake Lines (Front and Back)
20 Inch Weld Racing X-Lander Chrome Wheels with 35x13.50x20 Procomp Tires
Oilguard Bypass Oil Filteration System
Dieselsite Coolant Filter and External Transmisson Filter
4 Inch MBRP SS Turbo Back Exhaust with Muffler Delete Pipe (The Kitty is Safe)
Roll Lock Bed Cover
Quadzilla Recon XZT digital gauge (Boost, Trans, EGT)
RAVOwner is offline
Old 10-31-2008, 08:30 AM   #17 (permalink)
nitrogen's Avatar
the ford injectors work quite well and last as long as any other brand of diesel,IF you maintain fuel pressure. when the fuel filters plug or the fuel pump dies the injectors will croak very soon. unfortunately damage to the injectors occurrs while the engine still sounds ok, by the time you hear the engine starving the injectors are screwed. too bad ford won't add a system to monitor fuel pressure and activate a warning light, that by itself would have saved them millions in warranty and customer satisfaction. the best warranty is building it right so that you don't see the same components failing on every unit. its the designed in defects that drive customers away, that and replacing only the parts that totally fail instead of admitting what caused them to fail, fixing the real cause and any other parts that were hurt by the failure. ie change out 1 or 2 injectors when they failed due to low fuel pressure and then then in 2 weeks you're back to change another couple.if they fixed the pressure issue and all or more of the injectors they wouldn't have the same truck back 3 times for the same prob. oh and the customer would be a lot happier
nitrogen is offline
Old 11-01-2008, 02:27 PM   #18 (permalink)
quick question,had my 05 reflashed last year,just lately the truck wont start and when it does shakes like all get out,smokes like the glows plugs are only half working, how much are we talkin for a set of glow plugs.
usmale1954 is offline
Old 11-06-2008, 04:38 AM   #19 (permalink)
RAVOwner's Avatar
Just as an update I got my truck back yesterday after being at the dealership since Monday. It ended up being a bad No.6 injector and FICM (Fuel Inject Control Module). Both were replaced and the truck runs great now.
Roll Lock Bed Cover
RAVOwner is offline
Old 11-12-2008, 08:10 PM   #20 (permalink)
Travo's Avatar
Mine sat for a weekend and now the SOB won't start. Kicks over like theres no tomorrow but won't catch. What the hell??!?!?!?
US Army, Infantry - 2 tours in Iraq
2004 F-350, Single cab, Dually, FX4
168,000 miles
2006 Dodge 2500, Cummins 5.9, C.C., 4x4
48,000 miles
2006 Xcel 35' 10 ton gooseneck trailer
2003 Keystone Montana 35' 5th wheel camper
Travo is offline
Old 11-14-2008, 12:33 PM   #21 (permalink)
I'll tell you the truth!!!!!!! Rough starts,,,,,
Originally Posted by pat4nobjct View Post
I have an 04 f350 6.0l with 150k on it. as it is getting colder outside my truck starts fine everytime but in the mornings after sitting it will have a rough idle for 15-20 seconds then be fine. if the truck sits for a few days it will run rough for a couple minutes then straighten up and run fine. i live in cincinnati and it is around 30-40 at night. but even back in the summer if the truck sat for a week it would do this. any thoughts? thanks , Pat
Your problem is simple. Your injectors are having issues. When I bought my 04 I really didn't know much about it. Long story short. My truck had a rough Idle when cold and on every start. Worse when colder. Finally my truck got WAY!!!!! worse. It finally went from only sounding like a big rig on starts and smoothed out. To the steering wheel feeling like it was going to vibrate off the coloum. lol. I had to finally get every injector replaced. This will cost about 6 to 7 grand. Ford won't tell you this but the injector's in the 04 to 05's have very pooly designed injector's and they have had to be redesigned by International. I have all newly designed, remodified injectors in mine and my Truck runs freaking AWESOME!!! Here is the secret....... Go get the 200,000 mile warrenty from Ford and wait 3 month's or so and then tell them you having trouble out of them after you've have the warrenty for a while. warrenty cost 1500. That's it. It pay's it self off. Trust me. Even if your turbo when out it would still pay it's self off.
Phatbackhybrid
2004 F-250 6.0
4" lift, Procomp 315/75R16
AirAid
SuperChips FlashPaks
phatbackhybrid is offline
Old 11-18-2008, 04:02 PM   #22 (permalink)
blackwaterstroker's Avatar
Its normal...I live in the Houston area and it gets pretty cold down here too...My 6.0 will run rough bout 30 sec. and smooth out. When she warms up she runs better in the cold weather than the Gulf Coast heat.
John Boy
2003 6.0 Powestroke Fx4, Lariat, Sunroof, Heated seats.
straight exhaust. (sounds like a jet taking off)
285/75/16 BFG all terrain.
165k miles and no problems!!!
ALSO
1995 F-250 2wd xl 7.3 Powerstroke 5spd.
330k miles and a straigh exhaust. Sold and missed dearly.
blackwaterstroker is offline
