RPM's Going Haywire + Power Loss - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 06-16-2007, 02:11 PM Thread Starter
Hey all,
Long time lurker here (as guest). Wanted to share a problem I'm having and get some opinions. Searched the forums up and down and believe this may be related to the several 'power surge' topics but here I go anyway.
I've got an '05 F-350 6.0, all stock. 26,000+ miles
I recently have been experiencing problems while sitting at stop lights and such where the RPM's start fluctuating between 500 - 1500 (the truck wants to GO when they fluctuate upwards, similar to the other power surge threads I've read). Yesterday this started happening again. When the light turned green, I hit the accelerator and NOTHING happened. I had to idle drive through the light (how embarrassing) and was able to pull over and after a minute or two the problem cleared and I was able to zoom away. It was as if something wasn't telling the engine to fire diesel into the cylinders or something. The worse part is this is an intermittent problem. Drove fine last night.
I've already had it at the dealer once and they cleaned the turbocharger (I was doubtful about that solution and now I know it didn't fix it). I also had them do my 30k maintenance to make sure it wasn't a fuel filter or something.
So I'm bringing it back into the dealer on Monday (assuming I don't stall out). The dealership seems reputable but this seems like looking for a needle in a haystack.
Any suggestions I can give to the mechanic
Thanks,
Mike
KroolDeath is offline
post #2 of 11 (permalink) Old 06-16-2007, 02:14 PM
Re: RPM's Going Haywire + Power Loss
ICP sensor perhaps...mine did the same thing, and thats what they found.
2003 F-350 4x4 XLT FX4 SRW
Engine build date; 02Jan2003 --- SOLD
2005 F-350 4x4 Lariat FX4 SRW --- New Ride
Skoalbro is offline
post #3 of 11 (permalink) Old 06-17-2007, 05:01 PM Thread Starter
Thanks! That is what I was thinking based upon what I've read in the forums (and trust me I've read all the way to the end trying to get info).
Mike
post #4 of 11 (permalink) Old 06-17-2007, 08:53 PM
ford_doctor's Avatar
I Concur with the ICP being your problem. Though not as much a problem with 2005 model year engines, the sensors can still fail, and do! I repaired one last Friday for an intermittent surge complaint. I also had a 2003 last week that kept the idle at 950 RPM and did a few other strange things that threw me off.
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is online now
post #5 of 11 (permalink) Old 06-18-2007, 11:52 PM Thread Starter
Thanks again. I tell ya I love this truck, but getting nervous now. Supposed to be hauling my 5th wheel to Kentucky Lake this Friday for some vacation time (week and a half) with the family and if this happens while I'm hauling I'm in big trouble.
We'll see what the service department comes up with. Of course, it didn't happen today while I was driving it to the dealership. I swear it only happens when its really hot out (wasn't too hot today) but I think people think I'm crazy on that one. lol
Thanks,
Mike
post #6 of 11 (permalink) Old 06-19-2007, 09:59 AM
My ICP just got replaced, same symptoms, should throw a p2285 code. They cleaned the turbo and did a flash. Running better than new now.
be
2003 Lariat 6.0 Arizona Beige/Med Parchment Crew Cab 4wd Auto 3.73 born on 5/9/03
bedwards is offline
post #7 of 11 (permalink) Old 06-19-2007, 11:28 AM Thread Starter
Hmmm, just called the dealer to give them some "back seat mechanic" advise about the ICP and was told it is fixed after replacing the VGT solenoid.
We'll see.
Thanks all
Mike
post #8 of 11 (permalink) Old 06-19-2007, 07:16 PM Thread Starter
Nope not fixed. Stalled out on the way home from work. Let my foot off the throttle because I was going downhill, RPM's started fluctating between 500 - 1500. Dropped to 250 and stalled. Able to start it back up, rough idle at about 500 RPM's, put it in drive and just sat there. Pressed the pedal...nothing...
Finally after about 15 minutes the RPM's climbed to normal and was able to go although it just didn't feel right after that escapade.
I think my vacation is going to go bye-bye
Mike
post #9 of 11 (permalink) Old 06-20-2007, 09:41 AM
KroolDeath
Maybe you should just purchase an ICP sensor and install it yourself to see if it solves your problem.
Yeah, I know, why should you spend your own money to fix your vehicle if it is under warranty. Just a thought.
04/04 F250 6.0L Torqshift CC SB FX4
Turbo Cooldown Timer
Diamondback bed cover
Manual idle-up switch
(placing power onto PCM PTO wire)
Fumoto valve
Skweeker is offline
post #10 of 11 (permalink) Old 06-20-2007, 11:16 AM Thread Starter
Lol, that never occured to me to replace it myself.
Well back at the dealer this morning. These guys have opened up their schedule to get me back in so I really appreciate it so kudos to the dearlership (now if they can just fix it).
I got lucky today, right when I pulled into the dealership it started happening. Ran in there, got a mechanic and showed the problem to him. So he saw it firsthand. Questioned him about the ICP sensor. He acknowledged that could be the source.
Mike
post #11 of 11 (permalink) Old 06-21-2007, 10:01 PM Thread Starter
Well folks, they replaced the ICP sensor. The problem actually started happening while they were examining it, they yanked the ICP and the RPM's settled. Replaced it and all seems fine. Crossing fingers of course as it was intermittent.
However, I'd like to thank everyone for their assistance. Everyone was saying ICP sensor and that it was it appears to be. I also have to give kudo's to the dealer. Now some may say it took them three tries, but damn, it was a needle in a haystack trying to find.
So thanks all!
Mike
