Running gasoline in 6.0... - Diesel Forum - TheDieselStop.com
Old 09-30-2005, 08:05 AM   #1 (permalink)
One of my drivers made the dreaded "green handle is always diesel" mistake and pumped 3/4 tank of unleaded into the tank. It smoked a little and ran rough off idle, but otherwise ran normal. He drove it appx 30 miles on a delivery, and called to say it was running rough. Geez, on a 6.0 that could be a million things. When he got back I immediately noticed the exhaust smell wasn't right. We figured out what happened, drained it down as far as we could then re-filled w/ diesel. After a filter change, we'll see what happens. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2005 F-350 DRW 4x4 CC
2005 F-350 DRW flat bed
tucmoto33 is offline
Old 09-30-2005, 08:09 AM   #2 (permalink)
Re: Running gasoline in 6.0...
Charge him for the cost of the Gas? Hope it didnt over heat any.
03/04 F350 CC 4x4 Manual, 74 710k Pinzgauer, 95 Rx7
WonderChoad is offline
Old 09-30-2005, 08:15 AM   #3 (permalink)
If nothing's wrong with it--that to me would prove the 6.0 is one tough engine. Doubt any other brand could handle it that well without taking out some rods....
<font color="blue">2005 National 2nd Place Winner in Agricultural Mechanics in Repairs and Maintenance for The National FFA Organization.</font>
2004 Ford F-250 XL Regular Cab Longbed 4x2, 6.0L PSD/TS Auto, 3.73, stock for now. Tekonsha Prodigy, Curt Mfg. 10k WC/12k WD receiver hitch.
Traded in: 1995 Ford F-250 XLT Super Cab Longbed 4x4, 460, auto, 3.55's., K&N filter, glasspack duals. Miss everything about this truck but the gas mileage....
Some days you're the dog.....Some days you're the hydrant.
Mwheeler is offline
Old 09-30-2005, 08:28 AM   #4 (permalink)
airfooter's Avatar
A friend who is parts manager at dodge dealer says they've gotten several trucks in where this happened. He says they just won't run on it, and apparently none have ruined the motor!! I thought that was amazing. He was taking the gas, now contaminated w/diesel, and running it in his Tacoma and lawn mowers!! [img]/ubbthreads/images/graemlins/shocked.gif[/img] He said it ran fine on it.
How does that old saying go... "a spoonful of wine in a barrel of sewage is sewage and a spoonful of sewage in a barrel of wine is also sewage"
I guess late-model diesels never heard old sayings... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
airfooter is offline
Old 09-30-2005, 08:52 AM   #5 (permalink)
We put the drained fuel in an old class 7 yard truck, '62 Int'l., lol.
Odd, but it ran perfect after the initial idle stumble/smoke thing cleared up. I had a talk w/ the driver, don't trust green handles and smell it before you put it in. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 09-30-2005, 09:07 AM   #6 (permalink)
Our policy for drivers that feed unleaded to diesels is; whatever cost are to clean the fuel system is their's. Sorry, but there's no excuse for a professional driver to do that..... [img]/ubbthreads/images/graemlins/mad.gif[/img]
We had a driver do this to an 03 F350. We cleaned it out and set him to Michigan. That was around 72,000 miles ago. The 6.0 is a tough kid.
Wekiwa
2005 F250 CC SB 4x4 6.0 auto
Banks Big Hoss & K&N air kit & Xcal2 tuned.
Reg Return system with slighty larger injectors
A little turbo tweaking
Modified V-pipe and up-pipe assemble
Ceramic coated most stuff
Bypass oil filter kit
Black on Black
Wekiwa is offline
Old 09-30-2005, 02:57 PM   #7 (permalink)
My roomate filled his tank with gas on his 7.3 (2001) and drove for 80 miles. Said it started to backfire and spit flames so he shut it down. We towed him to the shop, and they drained the tank and filter. I started up ok but didn't run worth a crap. Had to have the injectors and pump replaced. Total cost was almost $4000. Now, my frends little brother filled up a 6.0 with gas and drove 30 miles. The ford service guy said the 6.0 shuts itself down when the gas got to the filter. I don't know how that would work, but no damage to that truck.
blakerj10 is offline
Old 09-30-2005, 03:02 PM   #8 (permalink)
We just put close to 150 miles on it and it runs perfect. Don't guess it hurt anything. Maybe that gas cleaned her out real good, lol.
Old 09-30-2005, 03:16 PM   #9 (permalink)
Do you want to stick with that analogy?
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
Old 09-30-2005, 03:31 PM   #10 (permalink)
Go get 'em Roof...............
I'm just wondering where someone finds a "professional" driver???
WS
2005 F-250 King Ranch 3.73LS CrewCab SWB 4WD Viper Remote Start/Alarm - Banks Cat-Back - SCT from the Froggy guy.
wellstroked is offline
Old 09-30-2005, 03:41 PM   #11 (permalink)
By definition a "professional driver" would be one who gets paid to drive. Therefore, that would make it easy to find such a person. However, it also means that being a professional driver has nothing to do with being an "expert driver". [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2005 F-350 CC 4x4 6.0L, Lariat bolt-action. 2.5" Leveling kit, 35*12.50*18 Toyo M/T's, Reflex spray in bedliner. Dieselsite Coolant filter. B&W turnover ball, B&W Companion fifth wheel hitch. MBRP 409 Duals.
Towed vehicle: 2006 Raptor 3712TS toyhauler fiver.(Holy Cow this thing is heavy!)
BigGreenDiesel is offline
Old 09-30-2005, 03:57 PM   #12 (permalink)
I think you're seeing my point............
Just cuz you're getting paid don't mean you know what you're doing....
WS
Old 09-30-2005, 04:08 PM   #13 (permalink)
WS
Which is why Pops or his brother do the interviews. Then can tell in minutes by a few questions if the person is worthy.
Its real scarey the folks we see with DOT certs that have no clue....
We had a guy tells Pops that its no different driving a church van or an 80,000lb truck. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Pops turned around and left him standing in the lobby! [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Wekiwa
Black on Black
Wekiwa is offline
Old 10-01-2005, 12:49 PM   #14 (permalink)
BP Amoco seems to think green and black should be reversed on some of their pumps. At least in Effingham, IL anyways.
The cashier said they've had numerous complaints, but nothing has been changed.
[img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
'05 F-250 FX4 SuperCrew - Screamin' Yellow!
- MBRP 4" stainless turbo back exhaust
rragan is offline
Old 10-01-2005, 03:39 PM   #15 (permalink)
BP likes to have green handles on the pumps when they don't even sell diesel at the station!
Brian Elfert
belfert is offline
