Rusted out oil pan 6.0 ??? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 08-11-2010, 04:51 PM Thread Starter
Hey Guys, quick question after just replacing both rear backing plates , rotors from being rotted out to dust thought i would look around a bit under the truck , up here in New england we have been getting killed with the new liquid de icer crap they use on the road it is eating our trucks alive, anyhow the oil pan is getting pretty crusty the past couple of years i have been smearing grease and oil on it trying to slow down the rusting process its not leaking yet but the flakes i took off were pretty thick and im concerened ,
I have read in certain posts that you can get the pan out from the chassis without removing the engine is this true , it is an 04 f350 4x4 dump truck . I am a former 15 year GM tech so i have mechanical experience just wanted to know what type of job it is and if its worth doing in my driveway on my back or pony up and let ford do it , also does anyone know the ford book time on this job ,
thank you
Vintageman is offline
post #2 of 4 (permalink) Old 08-11-2010, 05:46 PM
m-chan68's Avatar
I won't post the Ford book time to do the job, but I will tell you it IS a job that can be tackled in your driveway if you have the experience you indicate. Simply remove the engine mount bolts. Jack the engine up about a 1/2" on the crank pulley using a block of wood between the jack and pulley of course. Remove all the 8mm bolts securing the oil pan to the upper pan. Slide the pan down and rearward to the point where you have access to the two 8mm bolts that secure the oil pickup. Remove the oil pickup and remove the pan. Installation is just the reverse of removal.
Ford Diesel/Senior/Master Tech
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....and STILL hates working on E-Series with 6.0LFord Diesel/Senior/Master Tech
m-chan68 is offline
post #3 of 4 (permalink) Old 08-11-2010, 06:28 PM
rusty oil pan
rusted out so far :
trans cooler lines
p/steering cooler lines
rear brake line
fuel filler tube
ac comp tubes
power steering pump lines
could be more.
my 03 see's allot of snow plowing
my 2000 ccab 7.3 ,, looks great undernieth. except the rear diff cover
2000 f350 7.3 ccab 4x4 auto , DpTuner, AIH Delete, 4" Magnaflow . Only 130,000 miles on it.
and
2001 Ram 2500 auto w/cummins
24hrsparkey is offline
post #4 of 4 (permalink) Old 08-11-2010, 10:21 PM Thread Starter
thanks for the input, makes me feel better that you dont have to pull the engine to get it out like the 7.3 . not leaking but at least i know its not the end of the world when it needs to be done , Ive got an idea for ford and others STAINLESS steel can you imaging if they only made certain parts out of stainless would cost all that much , oil pans, backing plates , brake lines fuel lines , us truck guys would like that very much .
