Scangauge programming for 2007 6.0 - Diesel Forum - TheDieselStop.com
Old 11-02-2009, 09:21 PM   #1 (permalink)
Help....
Just bought a 2007 King Ranch f350 6.0... love the truck...
I need the programming codes for Scangauge II for it...
I would like to read the....
exhaust gas temperature (EGT),
mpg, trip miles,
engine oil temperature (eot),
trans fluid temperature (tft)
I would like to know also how to program the Scangauge... I do have the xgauge... but have not tried to program it yet.
I realize this may have already been discussed.. but I searched and searched... and read and read.... and if it has been discussed... I apologize for overlooking it..
xnman is offline
Old 11-03-2009, 11:11 AM   #2 (permalink)
MikeL46's Avatar
My Photos: (14)
The best suggestion I have is the Scangauge manual.
But, EGT is not available. And I'm not sure EOT is available for the 6.0.
Programming is a PITA! It took a couple of tries to get it right for TFT, but once in place it works.
Good luck,
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 11-03-2009, 11:54 AM   #3 (permalink)
ridintall's Avatar
According to the XGauge list, EOT is only available for the 7.3.
My only recommendation is to RTFM. It's pretty straight forward.
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
ridintall is offline
