Scanning Tool for 6.0 - Diesel Forum - TheDieselStop.com
Old 02-17-2013, 04:44 PM   #1 (permalink)
Hi Guys
Trying to find out what everybody is using to scan codes?
bgatz is offline   Reply With Quote
Old 02-17-2013, 05:49 PM   #2 (permalink)
Innova 3150 here. (Casual scanner.) AE w/Ford bundle is a premium/ professional one.
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 70,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/170,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline   Reply With Quote
Old 02-17-2013, 11:46 PM   #3 (permalink)
Will the innova pick up ford specific like the ae
6dotoh is offline   Reply With Quote
Old 02-18-2013, 01:26 AM   #4 (permalink)
Justin@DP-Tuner's Avatar
We have the Infinity available. It is a programmer/monitor, but you do not have to get tunes if you don't want to. You can always add them at a later date too if you decide you want them.
The Infinity will hold an unlimited amount of tunes, monitor generic and Ford enhanced PID's, read/clear DTC's, run tests(KOEO/KOER, buzz, cylinder contribution, glow plug), datalog, play media, and much more. You can check it out HERE.
Let me know if you have any questions about the Infinity. I would be glad to help you out.
Justin@DP-Tuner is offline   Reply With Quote
Old 02-18-2013, 09:31 AM   #5 (permalink)
6d, my Innova has never let me down pulling codes. With the AE, you have the ability to do most any specific diag test on a 6.0. I keep the Innova w/ me so I can help others mostly. It points me in the right direction. The Scangauge does the rest w/ on the fly diag. sensor readings.
