sensor - Diesel Forum - TheDieselStop.com
Old 11-19-2009, 09:03 PM   #1 (permalink)
sensor
ok guys check engine light came on had obd hooked up and its "injector pressure sensor" im not paying for this but how bad is it when one goes should i not drive it till its replaced? its an 03 6.0litre with 76,000 miles
teemgreen99 is offline
Old 11-19-2009, 09:19 PM   #2 (permalink)
Supporting Member
my03psd's Avatar
You'll probably get some surging or erratic idle.I'm sure so others will elaborate.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 11-19-2009, 10:17 PM   #3 (permalink)
4ceFed's Avatar
Yes surging and erratic idle, probably loss of mileage too. Although I would probably fix it because the reason it is reading wrong is because the sensor is leaking oil. If the sensor ruptures you would have loss of oil pressure.
4ceFed is offline
Old 11-19-2009, 11:15 PM   #4 (permalink)
it is going to get fixed as soon as part comes in but will a couple days cause any serious engine damage?
