Should I buy a set of electric cooling fans for my 2005 F250? - Diesel Forum - TheDieselStop.com
Old 12-01-2012, 06:50 PM   #1 (permalink)
Supporting Member
GIJOE0916's Avatar
I am considering buying a set of electric cooling fans for my truck. After my experience having to replace head gaskets for a second time I would like to protect my truck for getting anywhere to overheated. What do you guys recommend?
GIJOE0916 is offline   Reply With Quote
Old 12-01-2012, 07:16 PM   #2 (permalink)
chuckster57's Avatar
I don't know if electric fans will move the same volume of air as the stock fan. It has been discussed a few times in the IDI and 7.3 PSD forums and general agreement was stock was best.
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote
Old 12-01-2012, 07:32 PM   #3 (permalink)
Feedback Score: 2 reviews
Do you hear the fan come on? should be around 212-214* and sound like a jet plane. What kind of temps are you seeing ECT-EOT have you done a coolant flush change the egr and oil cooler when doing heads. Nothing better than stock fan if they are working right.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline   Reply With Quote
Old 12-01-2012, 09:16 PM   #4 (permalink)
Yea, you will not find a fan that will move as much air as the oem. Stick with that, maybe check your fan clutch. It is electric and sometimes they do fail not allowing the fan to lock up. As asked, have you heard it come on? If you are not sure then it hasn't... They are so loud, the first time it comes on you will pull over to see what is making all of the noise...
Member # 23075 Reged: 07/18/02
2005 Excursion w/ 6.0L PSD - Edge Insight, RCD EGR delete, Turbo Drain/Blue Spring/Oil Cooler Updates, Dfuser Coolant Filter, 240amp alt, fumoto.
2008 FX4 F250 CCSB w/ 6.4L PSD - Edge Insight, H13 Bi-HIDs, custom coolant filter, fumoto.
rock_doctor is offline   Reply With Quote
