Six Liter Woes - Diesel Forum - TheDieselStop.com
post #1 of 26 (permalink) Old 05-01-2011, 11:44 AM Thread Starter
Six Liter Woes
Well it starts already...
I bought a used 2005 F250 at the beginning of the month at my local Dodge dealer. 60k miles and in great shape. The first week i had it I put in an Edge insight and a Dieselsite coolant filter hoping to nip the EGR problems in the butt before they start. Immediately, the EOT and ECT were consistently 17-20 degrees apart at highway speeds. Yesterday, I started the truck and realized there was a problem. The truck threw so much white smoke out of the exhaust I thought someone elected a new Pope. The the engine began bucking and sputtering. I pulled over, popped the hood, and found zero coolant in the degas tank. It was full 2 days ago. I had it towed to the dealer where it's still under the 30 day warranty.
So here is where I ask the advice of the forum:
1. This does sound like the head gasket, or at least the EGR cooler, correct?
2. The dealer says they'll take care of it, but should I trust a Dodge dealer to know how to properly fix this? (oil cooler and EGR cooler as per TSB?)
3. If I can trust them to fix it, should I see if they'll put in stronger head studs and gasket and a better EGR cooler if I offer to pay the difference in parts?
If anyone has any direction or words of wisdom, it would be greatly appreciated. I'm so bummed about my truck.
2005 F-250 XLT Crew cab 65k+ miles
Edge Insight CTS Monitoring EOT/ECT/EGR/TFT/boost/volts
Husky floor liners
New factory EGR/ oil coolers at 65k
High idle mod
1979 F-350 Regular cab long bed gas pig
sixLiter1FT is offline
post #2 of 26 (permalink) Old 05-01-2011, 11:52 AM
ex mounty's Avatar
My Photos: (19)
Google TSB 09-8-3. Thats the TSB for coolant loss and will help them determine what that actual issue is.
Present it in a gentle manner if you want to directly give it to them.
Maybe ask them to give you a call when they determine what it is, and if it is head gaskets, be sure the heads are removed and checked for straightness/flatness and magnafluxed for cracks. They are well known for cracking in the valve seat area.
Dodge dealer would probably be OK with installing the headstuds if you get them first.
My issue with this whole thing is getting them to do the job properly.
My guess is that the truck was traded in knowing that this problem existed and they didn't want the expense of fixing it. If it was caught early enough, it might only be the oil cooler/EGR coolers.
No longer a member of this forum
ex mounty is offline
post #3 of 26 (permalink) Old 05-01-2011, 01:12 PM
xpbprox's Avatar
yup they sure do crack, mine were cracked on the valve seats so the machine shope put in hardened valve seats.
when i did my studs i replaced the stock egr cooler for one from bulletproof diesel
and if you did blow the gaskets then i would have them put studs in while they are in there.
also regardless of whether its the head gaskets or the egr cooler, you need to make them replace the oil cooler. it would be good if you could post your actual tempatures for the oil and coolant
04 F-350 XLT FX4 CC LB SRW leveled, SCT w/ innovative tunes, Edge Insight gauges, Str8 pipe, Studs, Bulletproof EGR, valve seats, 6.4 banjo bolts, updated fuel pressure spring
6.0 BIBLE
xpbprox is offline
post #4 of 26 (permalink) Old 05-01-2011, 01:22 PM
OT
OT's Avatar
Geez, tough way to start off eh! But, welcome anyways. You can print this out 6L Coolant loss/testing etc. Like ex says "getting them to do it properly" is ongoing complaint/concern with 6L (dealer/shop) repairs.
DIY u can only get mad at yourself!
Many reports here on "numerous trips to fix same problem" & those being done by tech's, not dodge. Lots of info. here you can print out & use if needed. I've done same, but chose my words carefully when I talked to tec.? It might get complicated, hopefully not. Update if u can. Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #5 of 26 (permalink) Old 05-01-2011, 09:48 PM
WaWheeler's Avatar
I feel your pain. This happened to me 4 months after I bought mine. Unfortunately for me there was no warranty at that point. $5K later I ended up with new studs/gaskets, egr delete, oil cooler etc. I just got it back yesterday and it runs fantastic. Make sure the heads are checked, one of mine was out .005 they were able to mill it flat so I didn't have to buy a new one. Also, Call Mike at Tousley ford and get any improved/updated parts since they have it apart anyway its worth the little extra now.
Good luck
Black 2005 F-250, 6.0, Lariat,CC,SB,4x4, leveling kit, 285-75-17's, ARP's, egr delete, coolant filter, edge insight CTS, SCT runnin a Looney tune.
WaWheeler is offline
post #6 of 26 (permalink) Old 05-02-2011, 06:43 AM Thread Starter
Thanks for the insight, I'll keep everyone posted when I hear something. Since I put the Insight meter in, my ECTs were in the range of 184-190 degrees. EOT was around 204 to 209 but as high as 212 at times. Mostly it would be 17-19 degrees apart while cruising but would creep apart at times. I printed out the TSB and will discuss it with the dealer as soon as I talk to them. Hopefully they have a good diesel tech.
Husky floor liners
High idle mod
post #7 of 26 (permalink) Old 05-02-2011, 09:42 AM
Ahhhh, The Dodge Boys. I have trusted mechanics in the states I tow in. One is in Spartanburg / Greeneville SC. A Dodge Boy, and one of the most insightful and talented 6.0 guys I have ever met. PS, I don't always carry my tools. b
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 78,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/187,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline
post #8 of 26 (permalink) Old 05-02-2011, 12:02 PM
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
Sounds like at the minimum a egr cooler and oil cooler. A good flush. I would however push for head gaskets and the whole show. If pushed I would buy the arps. They can be had for about 400 bucks shipped. thru various places.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
post #9 of 26 (permalink) Old 05-03-2011, 02:15 PM Thread Starter
The Dodge dealer called today. They acknowledged that the job is over their head and they're sending it to the local Ford dealer. The tech at the Ford dealer said he put his kids through college doing six liter repairs so it seems like things are going well. I'll keep everyone posted...
Husky floor liners
High idle mod
post #10 of 26 (permalink) Old 05-03-2011, 02:30 PM
ex mounty's Avatar
My Photos: (19)
Keep in close contact with the Ford Tech if you can. Might want to find out asap if the heads are coming off so you can have the ARP studs ready for the re-install.
post #11 of 26 (permalink) Old 05-03-2011, 04:39 PM
OT
OT's Avatar
SixL...OK, so now its wait time till tech. has in bay for diag. As mentioned try & keep close contact. SA usually go between, but maybe tech. will talk with you? 30 day warr. certainly a plus & hopefully gets fixed right. Update on diag. if u can? Good luck!
OT is offline
post #12 of 26 (permalink) Old 05-03-2011, 08:52 PM
mwilbur516's Avatar
I hope it works out for you. I had problems with mine as soon as I bought it too. After it was properly fixed, it has been a pleasure to own. The aggravation was worth it. I had to deal with a Ford dealer that was completely clueless. The second dealer I took it to had it diagnosed and fixed in a week (ARP's, Gaskets, ICP sensor o-rings, EGR and oil coolers). Stay in contact with the tech that is working on your truck. Push for new head gaskets and buy the ARP's (especially if you plan on any, even mild tunes). What year is the truck? If the Dodge Dealer is paying for the repairs, it may be easier for the tech to get you the whole nine yards (Studs, Gaskets, EGR and oil coolers, and whatever other upgraded parts that you choose to purchase.) Again, I hope it turns out as good for you as it did for me.
Alright just reread your first post and I see its an 05'
06 F250 XL, FX4, Upfitters, TBC, 15% window tint, 3.73's, Muffler delete, Cat delete, Fumoto valve, High idle mod, Zoodad mod, Harpoon mod, CCV mod, ARP studs, SCT Livewire w/ Looney Wild DD Tune, Dieselsite.com coolant filter, Glow Shift Fuel Pressure Gauge, Ford Blue spring upgrade, 6.4l Banjo Bolts, Upgraded turbo boots, Upgraded HFCM drain plug, Quick Tricks 58 volt FICM, S&B CAI, Monitoring EOT, ECT, EGT, IAT, Voltage and RPM
Horsepower is like a gun; You may not always need it, but it's nice to know its there
mwilbur516 is offline
post #13 of 26 (permalink) Old 05-05-2011, 11:08 PM
sixLiter1FT, any good news yet?
alha is offline
post #14 of 26 (permalink) Old 05-10-2011, 10:29 AM Thread Starter
Still no news yet...
I just called the Ford dealer today and they told me that they haven't looked at the truck yet. It's been 8 business days so far, I'm beginning to wonder if I'm being jerked around...
Husky floor liners
High idle mod
post #15 of 26 (permalink) Old 05-10-2011, 10:45 AM
a19berning's Avatar
Send a message via Skype™ to a19berning
Sounds like it. My ford dealer in martinsville gets mad if they dont have it in within two days. They rock and have amazing techs there though. Hope everything works out. I would ask them why it hasnt been looked at yet.
'10 F250 XLT
Crew Cab short bed, FX4
a19berning is offline
